2005 roadglide brakes were fine when I took the front wheel off to change the tire put it back on and the brakes were soft. Have to pump them a few times to have solid brakes they will stay solid if I don't move the bike but if I move the bike even just push it backwards ten feet they get soft again have to pump them up. Changed pads bled them out cleaned pistons on caliper an the anti rattle spring. Master cylender is only a couple years old. Anyone ever heard of this? Thanks in advance. Mike
Wrap a zip tie around the front brake lever really tight and leave it over night. See if that helps. This will allow any trapped air bubbles to rise to the top.
I don't think it is air. If it was it would need several pumps whether or not it was moved. I had the same problem when my front rotors were bent. When the bike is moved the bent rotors open the caliper up and it needs an extra pump or two for the pads to make contact with the rotors again. Straighten the rotors and you'll be fine. I used a dial indicator and a couple crescent wrenches to straighten mine out.
You need to clean the pistons in the calipers. They collect brake dust that keeps the pistons from moving correctly.
There are many threads on this procedure - it's a PITA but simple to accomplish.
