Front brake problems
Old May 31, 2014 | 01:10 PM
TWIN CAM 96's Avatar
TWIN CAM 96
This is what you need if your caliper pistons are dirty Service / Tech | Lyndall Brakes
Old May 31, 2014 | 02:20 PM
05ROADGLIDE's Avatar
05ROADGLIDE
As I said in original post already cleaned caliper pistons and greased anti rattle spring
Old Jun 1, 2014 | 08:15 AM
Buffalolake's Avatar
Buffalolake
I ran into this last year after having new tires put on. One of the rotors got slightly bent during the change. As the tire rotates, the bent rotor forces the pads out. The first pull of the brake is soft as the pads are getting pushed back into place. A quick pump and you have firm brakes. Then the cycle starts again...
Old Jun 1, 2014 | 09:42 AM
TexasMotorcycleRider's Avatar
If they were working fine before and you didn't open the system then I would check the rotor alignment. That was what you removed, most likely the culprit. No offense but some diagnostic suggestions don't really make sense here.
fftoddster
Apr 15, 2017 07:41 AM
Jeff Hester
Aug 13, 2016 09:52 AM
atwa
Oct 7, 2012 02:56 PM
bubbas1
Wheels/Tires
Aug 13, 2009 04:52 PM
kevdog
Aug 23, 2006 03:21 AM
