Need help with Progressive shocks on 99' Ultra.
Old Apr 1, 2007 | 11:29 AM
Wally's Avatar
Wally
Default Need help with Progressive shocks on 99' Ultra.
I posted this on the general forum, but, am hoping for more info from the touring crowd.
I recently installed a set of Progressive 412 shocks withheavy duty springson my Ultra. I weigh at least 250.
Hated farting around with the air. Never could understand how you could get an acurate reading with the guage when you loose some of the small amount of air you have to begin with as you remove the threaded on air pump hose from the valve.
Yesterday I rode the bike with the new shocks with three different ladies on the back.
First, my daughter, the brand new tire hits the fender on bumps.
I cranked it up a couple of notches and it was much better. Nice ride.
Next a friend of my wife. This girl is probably less than 150, but, I'm not asking. She definately weighs more than my daughter.The tire hits the fender now on real hard frost dips.
Next a larger girl, with the collar on the shocks set to second hardest position and I still had to be careful.
The problem I have is that the previous shocks would bottom, but, not let the wheel touch the fender, and, my bike thus far has been, empty saddlebags and no tourpac.
I figure the wife is between the weight of the two women and the tourpac and gear will be at least 50 pounds more and I only have one more notch on the collar.
Does anyone know how long the stock shocks are in case I've got some that are too short by a half inch or an inch and how does a person go about changing to heavier than heavy duty shocks?
Old Apr 1, 2007 | 12:20 PM
Biggzed's Avatar
Biggzed
Default RE: Need help with Progressive shocks on 99' Ultra.
Stock shocks on your bike should be 13" eye-to-eye. Never heard of anyobe needing heavier than heavy duty. I bet the shocks you put on are 12".
Old Apr 1, 2007 | 12:48 PM
Bigredone's Avatar
Bigredone
Sounds like you need to call the folks at Works and have them make the shocks you need. www.worksperformance.com or 818.701-1010. I had them build mine and luv em!
Old Apr 1, 2007 | 01:27 PM
baron3547's Avatar
baron3547
Exactly! You will never regret getting Works Shocks!
Old Apr 1, 2007 | 04:24 PM
Comfortably Numb's Avatar
Comfortably Numb
Make that three votes for Works
CN
Old Apr 1, 2007 | 08:18 PM
amfa118's Avatar
amfa118
I have a 2002 RK andI installed 412 HDs, 12 inches in length, and to tell you the truth I have never bottomed these things out. I weigh in at 225 and the wife around 125, with items in the saddlebags and a 150/18 rear tire on rear. I wonder if they sent you the wrong length also. Good luck.
Later
bundy43
Feb 20, 2015 07:08 PM
Corn Born
2014-2024 Touring Models
May 4, 2014 04:44 PM
iamrockinrich
Nov 29, 2012 06:12 PM
dkfxr
EVO
Sep 12, 2009 02:49 PM
Wally
Apr 1, 2007 11:26 AM
