Run/Brake/Turn module
Old Jun 11, 2014 | 03:13 AM
Watch Guy's Avatar
Watch Guy
Default Can I get the dual intensity
Originally Posted by nevada72
If you're talking about for the tourpack lights, I've been using the Harley unit for 3 years now without issues. I have Custom Dynamics led inserts. Works great.
bulbs for the rear or do I have to stick with the single intensity? The stock bulbs only have one filament.
Old Jun 11, 2014 | 04:43 AM
CGLTD's Avatar
CGLTD
I already had the RBT module from Harley that I took out of my 05. It works fine with the CD stuff. There are many options and some with strobe and/or flash feature. I also added the turn signal features to the tourpack including side markers.
http://s233.photobucket.com/user/chr...38F01.mp4.html
Old Jun 11, 2014 | 04:48 AM
Iceman24's Avatar
Iceman24
Call CD...they'll recommend the part, place the order and walk you through the install. Pretty much p-n-p and tapping into a few wires. So easy, a monkey's monkey can do it...
Old Jun 11, 2014 | 07:16 AM
nevada72's Avatar
nevada72
With the Harley kit you change out the sockets and go to dual filament bulbs. For the most part it's plug and play. It's been a while so I don't recall the particulars. But, if it sucked, I would remember it - like when I had to tear the whole front end apart to install the ridiculous Harley led blinkers. Now THAT I remember.
After the Harley wiring is installed you ditch the bulbs for the CD pods. Those are a little tricky in that they glue in place from the inside. Still, not bad. You'll need a load equalizer. I used the CD unit which has served me well for a year now. It plugs in under the seat.
Old Jun 12, 2014 | 02:12 AM
Watch Guy's Avatar
Watch Guy
Default Thanks
I'll give them a call before I order.
Broadway22
Electrical/Lighting/Alarm
Jan 3, 2019 08:35 AM
jayelrider
Jun 5, 2017 05:27 AM
SouthernGent
Nov 24, 2012 02:56 PM
HarleyReece
EVO
Jan 29, 2012 06:53 PM
Mike1397
Oct 6, 2006 06:13 PM
