eBay rear fender extension install help
Old Jun 11, 2014 | 11:23 AM
Fatboy Brian's Avatar
Fatboy Brian
What part of East Tn. are you in?
Old Jun 11, 2014 | 02:02 PM
Fatboy Brian
Here's a couple of pics of that same setup that I recently took off. It's the stock streetglide fender with the same extension you have. I hogged the extension holes out so that it could be removed easily. You could just clamp it into place and drill a couple holes through the extension and fender and bolt it up. I have also heard of people using 2 sided 3m tape. Hope this helps.
Attached Thumbnails eBay rear fender extension install help-20140611_145009.jpg   eBay rear fender extension install help-20140611_145028.jpg
Old Jun 11, 2014 | 05:41 PM
Harleyriding77's Avatar
Harleyriding77
I mocked mine up by taping up each side of the fender, then mocked the extension by using tape to hold it in place. Marked the holes with a marker. Removed extension. I staked the marks with a nice sharp"automatic" hole punch to make a divot so the drill bit wouldn't walk on me. Do not use a hammer and punch unless you have something to brace the fender on the way inside.
I then started by drilling out the holes in stages. Drilling a small hole and then working my way up to a size slightly larger than the bolt I was using to allow sight adjustment before tightening the bolt and nut.
hard on equipment
May 4, 2014 04:24 PM
bigirn
Jun 2, 2009 04:17 AM
ybn533
Dec 8, 2007 10:57 PM
chris97
Jul 26, 2007 05:26 AM
Andy883R
Jan 29, 2007 01:08 AM
