HELP on the road
Old Jun 11, 2014 | 01:13 PM
maryvillept's Avatar
maryvillept
Default HELP on the road
We are headed west from springfield MO towards tulsa today and Dumas TX tomorrow. I have a fork seal leaking and we are on the first day of a 4k mile trip so I'd like to get it fixed. Anyone know an indy anywhere along the way? Harley wants 3 hrs labor for one seal. Hell if I had my tools I could replace both sliders in less than 2 hrs. Thanks in advance.
Old Jun 11, 2014 | 01:16 PM
maryvillept
Also if I don't get it fixed, how dangerous is it once all the oil is out? All I'm seeing right now issome residue every couple hundred miles on fork leg and hwy bar
Old Jun 11, 2014 | 01:56 PM
flhxs103's Avatar
flhxs103
Well, it will most likely be bad once ALL the oil is out as it is in there for a purpose and it may get hot and wear internals out.
Be careful, it may get on your breaks or tire. Wrap a cloth and zip tie it if you can.
Good luck
Old Jun 11, 2014 | 02:15 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Hell just have them do both sides & rent a bike don't screw up your time off it's just a few bucks
Old Jun 11, 2014 | 05:55 PM
smithbrl's Avatar
smithbrl
RideMasters
918-828-0900 |
11327 E 20th Street, Tulsa OK 74128
I don't know anything about them but I called and they said they could do fork seal. Open 9a to 6p.
I didn't think to ask how much.
Old Jun 11, 2014 | 06:08 PM
Charlie Fogg's Avatar
Charlie Fogg
I thought i had this issue once but the problem was too much steering head grease. In hot weather it would thin out and run down to the forks where the seal is. Also blew around on other parts down there and the front of the tank. Someone else figured it out for me and I just got rid of the excess grease and cleaned everything up. I was told this is a common issue and almost always misdiagnosed as a leaking fork seal. Worth looking into...best of luck with this and the trip.
Old Jun 11, 2014 | 08:21 PM
BackRoader's Avatar
BackRoader
Well if I'm not too late try Mikes Cycle in Carthage. He is a few miles off I44. Does all my work. 1-417-358-4943. Or Hideout HD is in Joplin, 50 yards from I44..Good luck.
Old Jun 11, 2014 | 08:56 PM
maryvillept
I talked to hideout and they said unless its actually dripping when stopped then I should be good. Its just light dusting occasionally now.
CBCanada
May 27, 2016 07:02 PM
Raider Dana
Dec 11, 2012 04:32 AM
cripple
Nov 18, 2012 08:16 AM
gilmour68
Aug 22, 2011 09:40 AM
2007fxdc
Apr 23, 2010 05:34 PM
