Hot. I tried Redline Syn in primary. It didn't take long & the clutch started to slip at high rpms, going from 4th, 5th & 6th. I had my dealership check it out. My tech wanted to show me what the oil looked like. It was some nasty looking dark brown & smelled burnt. He told me that's he's seen this several times. Went back to HD Formula+ & never had any other problems. I run RedLine Oil & Trans fluid & they are outstanding.
I'm switching because I think I'm getting a little slip in the clutch. I read some good things about formula + and figured I would try it as I have 2 bottles laying around from the last bike. I tried to get some Rotella 10/40 but the 2 shell stations I went to were out of it or couldn't find it....... we'll see.
I noticed some slip after the the 1k service and syn 3 was used. It was noticeable on hard shifts. That hole I now use formula + and the clutch engagement feels better using it.
Originally Posted by apples402
Drain hot, i am an atf in primary user also, clutch releases better.
Great info guys, thanks............ gonna get to it today. of course I'll heat it up first. I was being lazy. I get a little ride out of it also..........
I ran all kinds of **** in my tranny and primary and finally gave up a few years ago and now just use Formula Plus because i saw no change or improvements with other crap....so easy to keep 1 fluid designated to primary and tranny...As for changing it i like to run it for a while just to stir it all up. Is would seem that most of the crap would be better drained out that way...
FYI, that oil should actually be thinner when cold as multi viscosity gets thicker as it gets warmer.
No.
I think you need to review how oil viscosity, lubricity and Winter weight works in hot and cold temperatures. Just think, "why do air cooled bikes run 20W50, and liquid cooled bikes run 10W30/40"... Hmmmm
