Seafoam in engine oil
Old Jun 18, 2014 | 07:42 AM
jus2anoyu's Avatar
jus2anoyu
Originally Posted by ynots
I personally would just let the oil do its job and change it at the proper interval.
Exactly!
Old Jun 18, 2014 | 09:55 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I have known "Old Timers" that when they pulled the drain plug on their vehicles, they would pour a quart of diesel in the engine to run straight thru and out.
My concerns then and now has to do with any residual left behind, as mentioned above.
However, the amount of Seafoam to do what you mention is probably not that bad.
I remember trying to tell the old timers why they should not do that, but you could have had a more effective conversation with a stump! Expect the flames, Bro, but it's your bike, probably no harm, "It's yo thang, do whatcha wanna do..."
Old Jun 18, 2014 | 09:59 AM
Biker John's Avatar
Biker John
I think I'd run Zmax in the oil rather than Seafoam, although its good stuff? IMHO???
Old Jun 18, 2014 | 10:54 AM
1HD2NV's Avatar
1HD2NV
Thanks guys, appreciate all the different takes on it. Agree it is probably not necessary but being an Operations Manager of a large Campus I see day in & day out how an ounce of preventative maintenance (being the key word here) goes a long ways. In the end dont think I will use it but again, always curious...
Old Jun 18, 2014 | 11:04 AM
fissco1234's Avatar
fissco1234
Originally Posted by Teardrop
I wouldn't do it. When changing oil there is always a few ounces left in the bike which means there would be some sea foam left in the bike. I don't know if it would be enough to hurt anything but why chance it.
With it added to your fuel, it will continuously be diluted and finally burned off. Not sure about putting in your oil when it will always be there to some extent, and added to (refreshed) at each oil change. Why fix a problem that may not even exist, just to possibly create a new one?
Old Jun 18, 2014 | 07:31 PM
twistedcherokee's Avatar
twistedcherokee
You could always throw in a half a quart of atf before the oil change. I have been tempted to get one of these that was mentioned before. http://shop.roguechopper.com/product...-a-touring-kit
Good luck
Toby
hitman1267
Oct 29, 2014 08:06 AM
TORQUEY
Apr 7, 2012 09:41 PM
jcallesano
Jul 30, 2010 12:58 PM
dexterdave
Mar 18, 2009 02:59 PM
nobody
EVO
Aug 5, 2008 01:58 AM
