Is it the Tires ?
Old Jun 24, 2014 | 05:10 PM
hdman6's Avatar
hdman6
I switched from the stock dunlops to the E-3's my last tire change. Made a world of difference. But, the town just tar snaked my entire road and I also have the loose feeling on them. I have to go thru this crap almost every day. So i look for the path going down my side of the road with the least amount of snakes. This helps a lot. Then in the turn i go pretty darn slow and also pick my path. heck of a way to have to ride. But better than dumping... I don't think any tire will work, the tar is slightly higher than the road and wet or soft will be slippery. just ride safely when u see them especially 2 up.
Old Jun 24, 2014 | 05:47 PM
Notgrownup's Avatar
Notgrownup
You just have to ride through them, they make you pucker up a bit but you just need o ride through them...
Old Jun 24, 2014 | 06:04 PM
my67pnycar's Avatar
my67pnycar
Dude, ride em out, look where you want to go and hang on, lol. Your tires are fine.
Old Jun 24, 2014 | 07:51 PM
Jinks's Avatar
Jinks
Actually it's fork oil weight & worn neck bearings. Change to a heavier fork oil & replace the worn neck bearings & you'll be surprised at the improvement.
papejr
Wheels/Tires
Aug 2, 2014 08:46 AM
composed
Jan 4, 2014 03:21 PM
hnesitd1
Jan 23, 2008 06:33 PM
vulhalla
Aug 27, 2007 01:32 AM
ROADRAGE98
Apr 7, 2006 10:45 AM
