tires that cup
Old Aug 26, 2007 | 08:21 PM
vulhalla's Avatar
vulhalla
Default tires that cup
Why does a front tire cup, causing the steering to wobble between 35-40 mph????
Old Aug 26, 2007 | 08:40 PM
Ram's Avatar
Ram
Default RE: tires that cup
Tires cupping is a natural wear indication. It does not mean that your suspension or something else is wrong. Its all the tire.
How many miles on those tires?
http://www.rattlebars.com/valkfaq/tirewear/#CUPPING
Old Aug 26, 2007 | 08:52 PM
vulhalla's Avatar
vulhalla
10,000 on front. I believe its making the steering wobble
tlb's Avatar
tlb
tire air presuure if it is low it will cause you tire to cup. nothing you can do about it after it has but get a new tire. not my opinion it what they told us in the safety course.
Old Aug 26, 2007 | 09:03 PM
shoptroll's Avatar
shoptroll
I agree. Low tire pressure will cause the cup and 10k is the usual life span of the stock Dunlop tires although depending on riding habbits and how far you care to push them you can get 13k to 14k.
Old Aug 26, 2007 | 10:19 PM
06dynablack's Avatar
06dynablack
use a metz front no more cupping
Old Aug 26, 2007 | 11:24 PM
goodbirds's Avatar
goodbirds
I believe cupping is caused by tire squirm on the pavement; low tire pressure, or heavy front braking, or a lot of hot curves will do it. My '84 Goldwing was notorious for cupping the front tire. I don't have that problem with the Harley's. The Goldie would wobble if you let go of the handlebars, even with a brand new tire on the front.
Old Aug 26, 2007 | 11:32 PM
biz44's Avatar
biz44
Usually a result of improperly inflated tire. Keep a eye on your cold tire pressures. I can normally go through two rear tires in the time it takes me to wear out one front. Metzler Marathon 880 do a nice job!
Old Aug 27, 2007 | 01:32 AM
Kolni's Avatar
Kolni
ORIGINAL: Ram
WHAT?
No tire should "cup".
Usually it is related to improper tire pressure.
texashillcountry
EVO
20
May 19, 2018 06:32 PM
Iron lHorse
May 30, 2016 11:11 AM
Ironbarr
Mar 4, 2010 10:25 PM
HDF Tech
Aug 7, 2005 04:01 PM
HDF Tech
Jun 25, 2005 01:29 AM
