Tire circumference help
Old Jun 19, 2014 | 08:44 PM
Sinner77's Avatar
Sinner77
Default Tire circumference help
Going from 130/80 17 to 120/90 21. What's the difference in overall circumference? I'd like to do the monotube sti drop the front but they're not available for the 14's until October. Trying to get an idea hoe much the ride height will be affected
Old Jun 19, 2014 | 09:12 PM
p51bombay's Avatar
p51bombay
You can't really judge that by the numbers alone, even in the same size, same manufacturer that can vary. Better to go to the manufacturers website and pull up the specs for a particular tire - not sure you'll find circumference but overall diameter should be there, make sure you look at the rim size they take that measurement on as rim size can affect the height of the mounted tire.
Old Jun 19, 2014 | 09:26 PM
Sinner77's Avatar
Sinner77
Oops, going to 120/70 21. Sorry, vodka.
Old Jun 19, 2014 | 09:27 PM
Sinner77's Avatar
Sinner77
Going on a 21x3.5
Old Jun 19, 2014 | 09:36 PM
qtrracer's Avatar
qtrracer
You don't care about the circumference, you care about the radius or 1/2 the overall height/diameter of the tire. That is the number either a + or - change from what you have now, that will show you the ride height change.
mrdarleyhavidson
Dec 26, 2017 07:42 AM
patrickd
Nov 13, 2014 06:41 AM
DrewCfromSC
Wheels/Tires
Apr 5, 2011 07:12 PM
godjunior
Jan 3, 2010 05:43 PM
KG
Apr 2, 2005 10:32 PM
