2011 will not crank
Old Jun 28, 2014 | 02:25 PM
alvinator's Avatar
alvinator
1st Gear
Default 2011 will not crank
I have a 2011 UC that had to sit about 7 months because of a couple of surgeries i had. Now, when i tried to start it, i got nothing. I took the battery to the dealership and the battery is good. I put it back in and no sound at all. Not sure where to start here before taking to dealership to work on. Thanks in advance.
Alvinator
Old Jun 28, 2014 | 02:26 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Have you forgotten about that special On and Off at the bars? I would have forgotten where the bike was if it had been 7 months.
Old Jun 28, 2014 | 02:52 PM
roadglider05's Avatar
roadglider05
Check and pull the fuses.
Old Jun 28, 2014 | 03:12 PM
alvinator's Avatar
alvinator
1st Gear
i have checked all the fuses and they are good. I have check the battery in the FOB and it is good.
Old Jun 28, 2014 | 03:37 PM
roadglider05
Had the same problem at Crossing Canada to Michigan, pulled fuse's and bike started fine, don't know why it happened. Never a problem before. Right at Customs before we were pulled in for being different, go figure.
Old Jun 28, 2014 | 04:46 PM
Lantern's Avatar
Lantern
Have you checked to see if your bike has thrown any diagnostic codes? Run a self diagnostic test. It may give you a clue.
Old Jun 28, 2014 | 05:29 PM
wurk_truk's Avatar
wurk_truk
When you turn the key on, does the fuel pump in the tank make priming noises?
Answer this, and that will cut the issues you need to look at in half.
How did you check fuses, BTW, with your eyeballs? That is NO way to check a fuse.
Old Jun 28, 2014 | 05:36 PM
VineRider's Avatar
VineRider
You didn't say if your lights come on or not. I'd really give that battery a second look. If all they did is check the voltage, that can be misleading. Amperage is what is required to turn the starter. It may be that the battery is failing under load.
Old Jun 28, 2014 | 05:46 PM
alvinator's Avatar
alvinator
1st Gear
I pulled the fuses out and check them with the meter. When i turn the ignition on, the lights all come on and when i flip the switch, i hear the pump come on. I have not done the self diagnostic test, never done one before.
Old Jun 28, 2014 | 05:49 PM
RollaMo's Avatar
RollaMo
+1
Answer both of the above questions.
If you can't hear the fuel pump priming, then make sure the "kill switch" is in the on position.
Rock the switch back and forth a few times.
In the off position, you will get nothing. No fuel pump priming, and no engine cranking.
