Turn signal problem.
Old Jun 30, 2014 | 12:22 PM
Wayne Pilato's Avatar
Wayne Pilato
Unhappy Turn signal problem.
'07 FLHT. Right turn signals go to high speed flashing. Right rear signal light goes out completely. Front signal works at first then reverts to rapid flashing. All bulbs OK (replaced when prob. started). Rear signal bulbs are single filament. Dealer installed mod. for rear running lights when new.
Any suggestions?
Old Jun 30, 2014 | 02:29 PM
ElGigante's Avatar
ElGigante
check your grounds on your bulbs, clean out the sockets, check for a pinched wire under the fender
Old Jul 1, 2014 | 09:58 AM
Wayne Pilato
Default Signal prob.
Thanx
Old Jul 1, 2014 | 10:17 AM
SeaZund's Avatar
SeaZund
check the wires behind the tail light under the fender; you could have hit some road debris and cut the wire under there. I had a similar issue after getting my rear tire replaced. The mechanic wasn't careful and the harness ended up running against the tire for X amount of time. I had to repair more than one of the wires. Always use heat shrink tubing (not electrical tape) if you have to repair any wires.
elktonjohn
May 10, 2018 05:01 AM
Grumppa
May 22, 2013 08:49 PM
Dispatch
Aug 8, 2012 09:25 AM
cmvsm
Apr 30, 2011 06:01 PM
papaschilling
Dec 30, 2005 09:33 PM
