Upper valve train noise solved
Old Jul 13, 2014 | 12:56 AM
twist1's Avatar
twist1
4th Gear
Thanks for the post. Have the same issue and replaced the lifters. Still have the noise.
This might be my lucky day.
Old Jul 13, 2014 | 07:10 AM
jus2anoyu's Avatar
jus2anoyu
My engine was silent for over 30k then slowly developed the tick. Many are getting good results from changing all the stuff under the rocker boxes. Supports, shafts, and rockers. I've got a complete new set of everything that will be going in when I go 107". Keep in mind, there are also a lot of other things that can make this noise, but the rocker and shaft play seems to be gaining popularity.
Old Jul 13, 2014 | 07:17 AM
journeyman's Avatar
journeyman
Seems a bit early to celebrate a fix.
Also;
The problem you described, is often times solved with a new set of lifters.
Old Jul 13, 2014 | 07:24 AM
SG-Jay's Avatar
SG-Jay
I noticed mine got louder when I switched to Amsoil, and I read someone else switched from Amsoil to Mobil1 and his was quieter. The real question, has anyone tried adjustable push rods, and if so did it fix it?
Old Jul 13, 2014 | 07:53 AM
jus2anoyu's Avatar
jus2anoyu
I've done everything except the rockers/shafts/supports and still have hot engine tick. It all helped to a small degree, but the majority of the noise in my bike is in the rocker boxes, and I will assume should go away when I replace the rockers/shafts/supports.
DRBUICK
Milwaukee Eight (M8)
14
Jun 30, 2018 02:33 PM
RG RON
Nov 14, 2017 09:04 AM
jcrawford14
Exhaust System Topics
Jul 11, 2011 02:38 PM
Milan
Jul 15, 2009 07:10 PM
webscrounger
Jun 8, 2007 05:41 PM
