Installed Headers...RPM Problems...
Old Jul 7, 2014 | 04:49 AM
geezer glide 56's Avatar
geezer glide 56
Originally Posted by gtrplaya0830
Just installed V&H Dresser Dual on my '13 SG. I have 4" Rc Component slipons as well and have the V&H feul pak. When I finished with the install and rode this afternoon, I noticed that the RPM's would, well, Ill call it a flutter. It seems like it flutters between 975-1000 Rpms at idle. Hasn't done this before. I also noticed as im cruising a at a steady rpm it seems to stutter a little and when I twist the throttle it hesitates some before it takes off. Im at a loss and have no idea what is causing this. Any help is appreciated!!
Did you get your o2 sensors mixed up ? The sensor with the black connector goes to the pipe on the rear cylinder.
Old Jul 7, 2014 | 01:13 PM
gtrplaya0830's Avatar
gtrplaya0830
I do have an arlen ness big sucker. I called V&H today and spoke with them and they advised me to unplug my O2 sensors and let the fuel pak do the work. So Ill try that and see what happens
Old Jul 8, 2014 | 02:33 PM
SBates08's Avatar
SBates08
Let us know how this works out for you.
2010 Limited with some stuff
Old Jul 9, 2014 | 11:48 PM
gtrplaya0830
Well I have not had any issues since I have unplugged the O2 sensors. Runs like it should now!! Very pleased!
Old Jul 10, 2014 | 05:49 AM
WILDWOOD_1124's Avatar
WILDWOOD_1124
Great! So how do you like the dresser dual?
Old Jul 10, 2014 | 07:45 AM
wurk_truk's Avatar
wurk_truk
Originally Posted by 09 YELLOWBIRD
No offense, but I would get a real turner and/or a real dyno tune.
I have had some bros that had the same problem with the fuel pak system.
If I may suggest, check out TTS Mastertune Turner, or a Powervision Turner.
Good luck.
YB
Lead them to water, can't make them drink.
Old Jul 10, 2014 | 11:42 PM
gtrplaya0830
I like the duals. Went from de-catted headers to those and its been a good change so far.
ron1026
Dec 31, 2014 09:49 AM
DarrenUltra010
Jun 9, 2011 09:30 PM
Other Sheep
Jun 6, 2010 09:18 AM
BIGDADI
May 7, 2009 06:24 PM
wrenchguy24
Jul 24, 2007 11:06 AM
