Bagger Frames
Old Apr 4, 2007 | 09:05 AM
Edmo's Avatar
Edmo
Default Bagger Frames
What differences in frames, if any, are therebetween the different touring models?
I'mmaking an assumption that all of the different touring models (RKs, Ultras, Glides, etc)have basically thesame frame with the obvious differences in the "bolt on" stuff like fenders and bags. The true question concerns taking a basic touring frame and making it into another variation of the touring line...
Edmo
Old Apr 4, 2007 | 11:38 AM
gunrunner's Avatar
gunrunner
Default RE: Bagger Frames
Youre right, there are some differences from some of the years, up to 97 then to 01 had a few changes but if you mean same year, then ultra,roadglide,classic,standard, roadking,street glide all have same frame/motor/trans/front end. Basic difference between models is add ons and sheetmetal and wiring harness (ultra and other radio models differ from road king models)
Old Apr 4, 2007 | 11:41 AM
jbhawley's Avatar
jbhawley
i concur w/ gunrunner...
since late 90's and 00 to present the frames are the same. I have an 01 that was a EG then a RK now an EG again. even the SG and RG are the same except for bolt on stuff. But the frame in all is the same frame.
Old Apr 4, 2007 | 03:17 PM
chiabate's Avatar
chiabate
In '96 for the '97 model yearwas the last time they really changed the frames. '96's were about an inch taller, that's why I've got a like-new Mustang Regal that I can't use on my new one. '02's got a beefier swingarm pivot. Yes the FLH/FLT have the same frames within these years.
Old Apr 4, 2007 | 07:10 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I thought the rakes were different between an EG and say a road king
Old Apr 4, 2007 | 07:40 PM
Dave_E's Avatar
Dave_E
As iffy as it is to assume sometimes, today you are correct grasshopper!
Old Apr 4, 2007 | 09:37 PM
casique's Avatar
casique
There has to be some difference if a 2007 RK Classic seat will not fit a 2007 RK Custom! At least that's what a couple of seat vendors have told me?????
Old Apr 4, 2007 | 09:54 PM
jmorton10's Avatar
jmorton10
The difference isn't in the frame, it's in the fit of the seat to the dash.
~John
Old Apr 4, 2007 | 09:58 PM
choochoo's Avatar
choochoo
Sometime between 01 and 06 HD did a change to the swing arm on the EG's
The axle is thicker and they now use cams to set belt tension, where before
they were set with individual adjusting screws.
To check neck rake, go to harbor freight. Buy a $6.00 magnetic angle finder.
Wheel straight ahead lay on front of fork. NO this is NOT EXACT but close enough.
Then next time you have fairing off, do same on front of steering neck.
There will probably be a two or three degree difference.
Old Apr 4, 2007 | 10:03 PM
GMONEY220's Avatar
GMONEY220
They must be,because i had to ask a couple of glide owners street and electra that had a 21"er up front,if they had raked the front end and they said no.Man i know i wear glasses but i dont think there the same.
ORIGINAL: Neggy ZRXOA 5248
