Oil Temp Sending Unit Wire Connector
Old Jul 21, 2014 | 05:41 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Oil Temp Sending Unit Wire Connector
While removing the plastic female wire connector from the oil pan mounted sending unit, the tab broke off which means the connector will not secure to the male end.
Anyone know if the connector and wiring can be bought separate (cut & splice) or maybe someone has one laying around collecting dust that they would part with for a few bucks....
Oh, I have to remove it each time I change my oil since I use the Scavenger Oil Change System...
Old Jul 21, 2014 | 05:44 PM
lp's Avatar
lp
I don't have a connector for you. I'm sure if you get one you will be able to cut and splice, but in the mean time try using some RTV. Apply some generously to both sides, let it dry, and you should be good to go for more than a few miles...
Just an idea.
lp
Old Jul 21, 2014 | 05:47 PM
soft 02's Avatar
soft 02
Replace the push on connector with a eyelet and a nut. Easy.
Old Jul 21, 2014 | 06:16 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Huh?....It's the newer type sending unit...don't think the eyelet & nut will work..
Old Jul 21, 2014 | 06:18 PM
fabrik8r's Avatar
fabrik8r
there are a lot of sources for electrical connectors, cheap, but you have to identify it first, that's the hard part. If its just the locking tab broke off you could secure the connector to the mating sending unit with a piece of heat shrink, fairly permanent solution and easy enough to cut off if you need to.
Old Jul 21, 2014 | 06:19 PM
HDV-GLIDE's Avatar
HDV-GLIDE
[QUOTE=lp;13013948]I don't have a connector for you. I'm sure if you get one you will be able to cut and splice, but in the mean time try using some RTV. Apply some generously to both sides, let it dry, and you should be good to go for more than a few miles...
Just an idea.
Why didn't I think of that.....hopefully it will release when I need to remove it next time..
jake556
Detailing
Aug 15, 2016 10:07 PM
harley_jeff
May 15, 2016 09:18 PM
customsoftail200
Aug 14, 2015 01:49 PM
siggybrain
Apr 10, 2008 05:09 AM
firespy999
Apr 27, 2007 11:21 AM
