I've read many threads where a large percentage of the 103's developed a slight ticking noise in the upper end at around the 2200 to 2800 RPM range, and is considered normal. My question is has HD done anything in the last couple prodution years to solve this ?
Thanks in advance Jonnierock
I thinks it "normal" from all the threads I have read. I have not noticed it since I removed my RKC windshield, the ticking is almost non existent. The windshield magnified the sound and sends the engine noise right to my ears. If I can't notice it when its ideling or running with out the windshield at lower speeds then I think its a non issue. I have had a lot of different bikes and they all make weird upper or lower ends sounds.
Yeah they gave the bikes better sound systems...lol.
My 14 limited is definitely quiter than the 10 and 12 limited. Either that or the radio has noise cancelling. I had learned to live with the noise. Most say it is the rockers moving on the shaft. The 103's on dynas and softtails don't make any noise at speed. Could be the lack of wind shield.
As said; syn oil and fairings/windshields capture the noise and direct it to our ears.
That said, mine never made much noise compared to the 113, and now with the 57H's and proper pushrod adjustment, it is uncommonly quiet.
The specs on the newer TC's are super loose but with all of the new metals and CNC machining, they seem to be holding up well.
I have over 200K miles on the Evo bike before I yanked the 80CI, I hope to get this on my '12 TC.
I dont know that its a "Large percentage" but yes, there are many. Some say its the rocker side clearance, some say its the hydraulic tensioners, some say its just all the inner workings of an air cooled twin cam. I say if the noise is there from the start (Or a very low mileage) its probably gonna always be that way. If its something that comes on with greater mileage, like mine, its probably something that can be fixed. Technically, im not even sure its a matter of being broken, as I believe some are just louder than others. As others have stated, windshields, fairings, lowers, radios, or the lack of these certainly affect how obnoxious the rider percieves the noise to be....
The top end of my 2 week old Street Glide doesn't sound one bit quieter than the top end of the 09 EG Classic with 85000kms that I traded.So I guess it is normal in my case.
Ran the Blue Ridge Parkway yesterday and today. Yesterdays noise was the worse I ever heard. Today before hitting the BRP I put in some octane booster and what a difference. I was in third and fourth gears quite a bit so as not too lug the engine and did some cooling off stops also. On the highway at cruising speeds it's a great engine. I guess 93 octane wasn't quite enough in the hills.
