New member with problems
Old Jul 25, 2014 | 10:45 PM
04glideTC's Avatar
04glideTC
changed the filter, added some seafoam.
topped the tank off and got it to start. I had to give it some gas to start, but it started and 3-5 seconds it cut off. Tried to start again and it wouldnt. Could it be the oil pump?
Old Jul 26, 2014 | 01:30 AM
Def Mute's Avatar
Def Mute
There is no 'low oil pressure' equipment that will prevent that bike from running if there is no oil pressure, so I doubt it's the oil pump keeping it from running...
Gotta ask, did the oil light go off while you were riding it home, before it shut down on you?
You also haven't stated if it is carb'd or EFI. Necessary info. Different solutions depending on which. Although, you did mention the fuel pump comes on. That would indicate EFI...
Since the bike was on 'E', I would suspect dirty tank. Fuel filter could be plugged, water could have accumulated, etc. Use flashlight to look inside. If you, or your buddy, feel confident enough, pull the fuel filter/pump assembly. Check for clean filter, and cracked hoses. Many people have a problem with small pin holes in the fuel line, be sure all hoses are in good shape, and replace filter if necessary.
After that, diagnose electrical and fuel delivery system...
Forgot to mention, get a service manual. It will prove it's worth the first time you open it...
Old Jul 26, 2014 | 03:14 PM
04glideTC's Avatar
04glideTC
I just changed the fuel filter, added sea foam n 2 gallons of 91. Tank is about 3/4 full.
Old Jul 26, 2014 | 04:07 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the oil light is staying on because there is no oil pressure without the bike running,i would;d start with all fuel related sensors and injectors,the "strong smell" of gas tells me its getting too much fuel. from bad tps to a leaking injector.pull the air cleaner and check the blades i have seen those spin on the shaft.
Old Jul 26, 2014 | 05:28 PM
petdoc94's Avatar
petdoc94
Originally Posted by Iceman24
Definitely needs a good service...especially if bike sat for any length of time. Agree w/Mike on hunting down decent mech..worth their weight in gold. Unless you're in a position to tear into motor, best option for getting back on the road quickly.
Alot less headache to find a good Indy..You be glad you did...
Old Jul 26, 2014 | 06:49 PM
dochawken's Avatar
dochawken
Sounds like it is starving for fuel..it cranks over...but runs for only a short period.
Old Jul 27, 2014 | 05:21 AM
just plain john's Avatar
just plain john
Remove the air cleaner and spray some starting fluid (ether) into the throttle body while trying to start it. It can only be one of two things, spark or fuel.
Old Jul 27, 2014 | 10:37 PM
04glideTC's Avatar
04glideTC
Took the air cleaner off and tried starting it. no luck. little bit a smoke came out the side by the air cleaner. Tomorrow ill take the tank off and get to the injectors.
Old Jul 28, 2014 | 10:20 PM
04glideTC's Avatar
04glideTC
Should i clean the injectors or replace?
Sic9
Mar 26, 2018 02:43 PM
bigcat1043
Sep 14, 2012 04:39 PM
FXD2003Rider
Jul 13, 2012 01:51 AM
Badillac
Jul 10, 2012 03:34 AM
Streets of Fire
Sep 29, 2009 07:15 PM
