Front brake lines leaking...
Old Apr 6, 2007 | 09:39 AM
Stoner's Avatar
Stoner
Default Front brake lines leaking...
From right where the "y" connector attaches to the triple tree below the fairing. I noticed the drips on the front fender and splater on tank, fairing inner, etc. Anyone else having this problem?
Old Apr 6, 2007 | 09:52 AM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
Default RE: Front brake lines leaking...
Now you have an excuse to replace the lines with stainless steel braided lines.[8D]
Old Apr 6, 2007 | 09:54 AM
sleepneagle's Avatar
sleepneagle
I suspect a metal fatigue crack at the block. I would replace with the stainless braid line kit and be done with it.
Old Apr 6, 2007 | 01:07 PM
jbhawley's Avatar
jbhawley
ditto to replacing w ss
Old Apr 6, 2007 | 01:40 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
get the fluid off the paint before it eats it away
Old Apr 9, 2007 | 10:45 AM
Stoner's Avatar
Stoner
Dealership checked it out and says it's head grease that liquified (from radio heat?) and dribbled down. No paint damage, but it splattered everywhere thanks to the wind.
Old Apr 9, 2007 | 10:48 AM
kfmorris's Avatar
kfmorris
No problem yet. Time to go to stainless I guess.
[IMG]local://upfiles/24659/3046D20882AD490D8BACA8EBC3C7C2D8.jpg[/IMG]
Old Apr 9, 2007 | 05:49 PM
choochoo's Avatar
choochoo
DOT 4 (what's in most bikes ) is not as corrosive to paint as the older dot 2 and 3.
also the new clear coats withstand it better than the old enamel paint.
But yes it could be a crack in the block or line.
But it could just be the copper banjo washers need replaced.
Only a close observation will tell for sure.
But a good set of aftermarket stainless steel would be a good way to go.
rkdouglas
Powdercoat & Paint
May 14, 2015 10:04 PM
rdunn22
Aug 9, 2012 07:19 PM
cmosentine
Jul 27, 2012 03:51 PM
T-Bird
Jan 12, 2012 07:21 PM
archergodwin
Jul 3, 2009 12:14 AM
