2004 ultra tranny problem
Old Jul 31, 2014 | 06:38 PM
bracer's Avatar
bracer
3rd Gear
Default 2004 ultra tranny problem
at sustained speeds of about 70 mph my ultra is spewing oil from tranny vent it is not overfilled it is gaining oil from the engine how many avenues is there for this to happen ie gaskets or seals
Old Jul 31, 2014 | 06:40 PM
mkguitar's Avatar
mkguitar
the twin cam tranny is completely separate from the motor ( as are all HD Big twins )
check that you have correct dipstick or even drain and refill tranny with correct amount of correct type fluid per your manual ( about a liter).
do check that the vent is clear- wasps often make a home in the tranny vent
Mike
Old Jul 31, 2014 | 06:45 PM
bracer's Avatar
bracer
3rd Gear
Done all of that does the oil pan not have two sides to it one for the engine the other for the tranny
Old Jul 31, 2014 | 06:53 PM
mkguitar's Avatar
mkguitar
Oh, you are right the oil pan is shared, but fluids shouldn't be able to mix...the tranny drains from a hole in the bottom of the tranny case, through a passage in the rightside of the oil pan, then to the drain plug.
I don't see how the fluids could mix unless the drain passage has been busted due to overtightening the drain plug ( or a busted tranny case)
you may have to drop the pan...
if you go to:
http://partsfinder.onlinemicrofiche....HOUSING-W/-PAN
click on motorcycle, then select model year, then model, select transmission housing with pan
you'll see
if I wanted to check this, I'd use compressed oil to pressurize the oil tank at the filler to about 25 psi - then watch/listen for air escaping
mike
Old Jul 31, 2014 | 07:20 PM
bracer's Avatar
bracer
3rd Gear
tried pressurizing the crank didn't work just vented at the intake going to drop pan and check things out thanks for the input
Old Jul 31, 2014 | 07:28 PM
Stiggy's Avatar
Stiggy
The primary vents to the tranny via the clutch pushrod threaded adjuster. You'll notice that there a "flat" on one side of the adjuster so that there's always avaiable venting if needed. Could you have engine gases blowing past the jackshaft seal thereby pressurizing the primary?
Old Jul 31, 2014 | 07:39 PM
bracer's Avatar
bracer
3rd Gear
I put red primary oil in so it would stain the tranny oil and I would know if it was passing from the primary please keep the ideas coming sooner or later the problem will be solved
bigtexasrob
Oil Archive (no new posts)
19
Mar 27, 2021 03:39 PM
Senorjeem
Oct 28, 2013 05:21 PM
tperk100
Mar 13, 2008 05:25 PM
christian0632
Oct 29, 2007 07:19 PM
Dancemax
Aug 6, 2007 07:23 AM
