Which spark plugs?
Old Aug 2, 2014 | 07:25 PM
checkers's Avatar
checkers
Originally Posted by bigheadted
Pulstar= totally bad ***. Starts better, better mpg and felt power. Ping is gone. aaaviva la snake oil !! Does cause drought though because it has not rained since I put em in the motor.
Your the one!
Old Aug 2, 2014 | 07:36 PM
SafetyMan's Avatar
SafetyMan
Reckon they don't drug test where he works....
I run the 6R12's. Never had a problem. I do have a set of NGK's in my box that I've never used...
Old Aug 2, 2014 | 08:57 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
10R12s work also, just a little colder.
Old Aug 2, 2014 | 09:15 PM
Veekness's Avatar
Veekness
Plugs is plugs as long as they fit in the hole and don't get whacked by the pistons. Their job is simple. Only critical thang about 'em is the heat range.
Now. Somebody start an oil thread. ..
Old Aug 2, 2014 | 10:02 PM
Max Headflow's Avatar
Max Headflow
I run Champion RA6HCs tho the RA8HCs are closer to the stock heat range.. Baggers have Tmax so no issue with screwed up ion sensing..
Old Aug 2, 2014 | 10:59 PM
dochawken's Avatar
dochawken
Made me laugh...but so very true! Well done
Old Aug 2, 2014 | 11:11 PM
rubberguy's Avatar
rubberguy
Thumbs up
I use Denso Irridiums IXU22 in my 07 ultra. runs great.
Old Aug 3, 2014 | 12:26 AM
bklynbob's Avatar
bklynbob
I used them in my '01 FXD,great idle and starting. I don't use them in the RK,i thought they were incompatible with ion sensing........
Old Aug 3, 2014 | 06:27 AM
Tn.Heritage's Avatar
Tn.Heritage
Run the stock plugs again with no worries, good ole 6R12's.
Old Aug 3, 2014 | 06:42 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Every time I check mine, they look excellent, still running OEM stock plugs.
Whenever I change, the same will fill the hole again.
OP, how do yours look? How many miles? Any problems?
tonetls
Jun 1, 2014 06:41 AM
Mike Kautzman
Dec 25, 2010 12:00 PM
loc
Exhaust System Topics
Sep 18, 2009 08:39 PM
mjaw
Nov 13, 2008 12:50 PM
Nevar
13
Mar 16, 2005 05:44 PM
