I am getting ready to Replace my front brake pads. I have a manual and found how tos on youtube. I have done this task many times on cars and trucks. I have never found it necessary to remove the Master cylinder cap on vehicles. So my question is it really necessary on the bike?
I see no reason to remove the master cylinder cap unless you are changing / adding fluid.
You definitely should remove the master cylinder cover to allow for the displacement of fluid from the calipers back through the lines due to the pistons being pushed backed into the caliper bores. There is a significant amount of fluid being dispersed back through the system and it needs somewhere to go. By not removing the top there is a strong probability of further problems, including master cylinder problems and fluid oozing/squirting out of the seal at the top of the master and leaking/dripping out onto painted surfaces of the scooter. Brake fluid can/will wreak havoc with painted surfaces.
If you have never topped off the master cylinder as the pads have worn down, you wouldn't need to worry about adding any additional fluid. However I agree that this is the PERFECT time to change out the fluid.
Your statement is correct, but consider this... The operative word is "if" ... What if a tech has topped off the fluid during a scheduled service? Having been an ASE mechanic my whole life ( and owning my own business for more years than many are old here ) has helped me to remember to never assume anything. If there's a possibility, address your concerns accordingly.
...or you can just crack open the bleeders as you spread the pads - keep the fluid off the paint, check fluid level when finished. Flush when you want to...
