6 speed transmission failure
Old Aug 9, 2014 | 11:22 AM
FLHXDAN's Avatar
FLHXDAN
Default 6 speed transmission failure
On my 2009 flhx, the primary shaft transmission bearing is failing. The plastic cage that holds the ball bearings in place is coming apart and the pieces have caused the seal to leak oil.
There are a lot of small metal pieces on the oil drain plug and a light shining into the oil reservoir reveals a lot of small metal pieces in the fluid.
The bike has about 26000 miles.
Old Aug 9, 2014 | 11:35 AM
Devildog0311's Avatar
Devildog0311
Sorry to hear the bad news, hope it won't be to costly.
Bob
Old Aug 9, 2014 | 11:47 AM
scottt's Avatar
scottt
Hope you have a warranty.
Old Aug 9, 2014 | 11:48 AM
bigskyroadglide's Avatar
bigskyroadglide
Probably due to over tighten primary chain due to automatic chain adjuster
Old Aug 9, 2014 | 11:51 AM
krwould's Avatar
krwould
Get rid of the auto chain adjuster!!!
Old Aug 9, 2014 | 11:57 AM
Max Headflow's Avatar
Max Headflow
I suspect that he's talking about the main drive gear bearing as the inner primary bearing does not have a plastic cage.. If that is the case, it is more than likely the drive belt was too tight not the primary chain.
Old Aug 9, 2014 | 12:21 PM
krwould's Avatar
krwould
drive belt tension and primary chain tension can both cause that main gear bearing to fail. I had a conversation with Mark at Baker about the very subject because I was getting a lot of primary noise, the auto tensioner was the culprit, went with a manual adjuster on my 2010 RK. He told me that it can also cause main gear bearing failure.
Old Aug 9, 2014 | 12:24 PM
krwould's Avatar
krwould
Check out this thread.... interesting.. https://www.hdforums.com/forum/gener...g-failure.html
Old Aug 9, 2014 | 12:32 PM
FLHXDAN's Avatar
FLHXDAN
It is the bearing on the transmission side. I probably did not name it correctly. There are a lot plastic pieces stuck in and around the seal which appears to have caused the seal to leak oil. The bearing looks like 2 rows of ball bearings. Planning to pull out the transmission next
Old Aug 9, 2014 | 12:37 PM
FLHXDAN's Avatar
FLHXDAN
krwould, Thanks for the part number 8967 thread. That is the bearing, it appears to have a plastic cage which is falling apart. I have not removed the bearing yet. I don't think I even want another Harley tranny.
