So on friday me and the wife planned to ride out to Las Vegas from SF and a little past halfway my wifes boot was shinny and noticed oil over the head pipe and all the way to the bag. I cleaned it and every stop it was happening and once into vegas i took to the dealer out there and they wanted me to leave it but the next day we were supposed to head back so i just picked up some oil and went home the following day. Cleaned it each time and the next stop same thing happened. I dropped it off at the dealer this morning and they said it might be a push rod seal but ill know in a day or two. Anyone else have this happen?
My wife's SGS had a puddle under the air cleaner (Screaming Eagle Extreme Billet), and seemed more than blow by. Oil level was okay, not over-filled. Took it to the dealer where they said they could not find anything wrong. It stopped leaking for awhile, but now after I added 1/2 quart of oil it is dripping again. I double checked and it is not over-filled.
Dunno if we need to take it back in or if is just blow-by.
Sorry, but if it is blowing by that bad, it is over filled.
Run a half quart "low", it is still within spec, and the problem is solved.
Read this, it is not specific to Harleys, but you get the idea...
