Spark Plug Gap
Old Aug 12, 2014 | 10:01 PM
MPRIDER's Avatar
MPRIDER
Default Spark Plug Gap
Hello All,
Recently have had a problem and have not had much luck finding the answer with countless google searches! I have recently changed the factory plugs on my 13 street glide for new factory plugs. I gapped them using a round gapper from autozone and put the electrode in the middle of the line at .40. When I went to start the bike it started real rough... I then checked the gap on the old plugs and one had the electrode right in the middle of the .40 line and the other was at .45. The bike seems to run fine going down the road, but doesn’t fire up as nicely as she used to. I would appreciate any help from this amazing site full of experienced folks!
Thanks!!
Old Aug 12, 2014 | 10:10 PM
Retrop's Avatar
Retrop
If you have a late model touring bike that uses 6R12 plugs then 40 is where you want to be. Unless you have gotten a cracked plug (unlikely) I doubt that the problem is plug related.
Old Aug 13, 2014 | 03:04 AM
Fast Aire's Avatar
Fast Aire
Former Sponsor
A gap difference of .005 will make little difference on a street bike. I agree with Retop, but in your case, I would install a difference set of plugs and give that a try.
Old Aug 13, 2014 | 05:35 AM
Tn.Heritage's Avatar
Tn.Heritage
Try the Gap at 0.35 and see how she runs !!
Old Aug 13, 2014 | 06:58 AM
ndnguyd's Avatar
ndnguyd
Put the old ones back in and see how it runs.
Old Aug 13, 2014 | 07:27 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Put the old plugs back in, test the bike. Does it now start easily and run smoothly? If so, at least one of those new plugs is bad.
Replace one of the old plugs with one of the new plugs. Test the bike. Does it now start easily and run smoothly? That new plug is good. If it starts hard and runs poorly, the new plug is bad. Replace it.
Replace the 2nd old plug with the remaining new plug. Test the bike. Does it now start and run easily and smoothly? If so, both plugs are good and you've a different problem to chase down and correct. If it starts hard and runs poorly, this 2nd new plug is bad. Replace it.
Old Aug 13, 2014 | 03:04 PM
MPRIDER's Avatar
MPRIDER
Thanks for the help guys! I figured i would just widen the gap just a little before trying the old plug trick and it seems to be starting better now. I will keep the old plugs just in case. Cant express enough how great this site is!!
Locadd
Shovelhead
21
Jul 3, 2018 09:24 AM
Leonfxwg
Mar 10, 2013 08:37 PM
Hunter1979
Apr 7, 2011 07:28 PM
ajnccn
Jul 15, 2010 08:18 AM
yandeltx
Mar 9, 2010 07:03 PM
