The ordering process has begun for my road glide conversion!
As for the speedo and tach housing, since I ordered a color matched inner fairing they were included. Like redbeard said, roadglide.org or eBay may be the route to go.
Can wiring be extended, or do I defiantly need a new fairing wire harness? Looking at cost, the harness looks to be pricy.
Did any of you find a good source for a used speedo and tach housing? I have looked on eBay, and the forums, not finding much.
I stripped my bike to the frame as part of the overall project, and rewired it up with a new, civilian main harness, which laid the groundwork for everything else. Then it was just a matter of sourcing an interconnect, handlebar wiring, gauge package, and the fairing parts.
You guys who are starting from a batwing bike have half the work already done, all you need is the interconnect, and the fairing parts.
Unless you enjoy, and are proficient at wiring, I'd advise you find an interconnect. Its much nicer when all the terminals are where they should be, and nobody will be able to tell it didn't come from the factory that way without decoding your vin.
I think I spent close to 2K on my conversion, which included the main and interconnect harnesses, handlebar wiring and switches, inner, outer, speedo nacelle, gauges, OEM radio and all the necessary brackets. I'd do it again in a heartbeat, it was the best money I spent on this bike.
