DK Discrete Breathers
Old Aug 18, 2014 | 02:06 PM
DK Custom Products's Avatar
DK Custom Products
Sponsor
OP, maybe I missed it, I apologize if I did, but what type of Air Cleaner are you running?
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Old Aug 18, 2014 | 02:07 PM
hardheaded's Avatar
hardheaded
what about drilling a hole in the bottom of the stock cover for the hose to exit?
Old Aug 18, 2014 | 02:50 PM
aces25's Avatar
aces25
I run the breather bolts and do get oil misting. It's not too bad and worse under harder acceleration. It doesn't take too much effort to clean it up, but I still entertain the idea of using the discreet system to eliminate the clean up.
Old Aug 18, 2014 | 03:05 PM
Smokey Stover's Avatar
Smokey Stover
This is what I came up with after being unable to find any system that would work with a SE stage one backplate, I went with dual hoses parallel to bottom of rocker box covers then down to hidden catch can in cowbell. Marine shrink wrap over fittings tapped into backplate really cleaned it up.
Old Aug 18, 2014 | 03:20 PM
aces25's Avatar
aces25
Very clean and well done. Got a write up of how you did it?
Old Aug 18, 2014 | 04:22 PM
nemick's Avatar
nemick
Natalie, right now I'm running the SE A/C. I realize this wouldn't work with your breathers (of either type), so if I do this I was planning on running your complete set up.
Old Aug 18, 2014 | 05:09 PM
MyFirstHD's Avatar
MyFirstHD
Originally Posted by riseagainst82
I have their 587 outlaw intake on my dyna I just ordered the discrete kit I'll let you know how it works.
I got this combination with stock pipes and love it. Breather Bolts didn't work for me, I could smell oil when it got hot and some oil would come out. The discreet line down under the frame is perfect.
Old Aug 18, 2014 | 08:29 PM
Smokey Stover
Yea,sort of. I started with a prototype backplate,tapped 1/8 npt brass plumbing fittings to a tee then humped hose over injectors centered between heads. Didn't like the hump in hose creating a trap. Anyway this thread covers the rest of the story.
https://www.hdforums.com/forum/engin...-pressure.html
AZRenegade
Aug 30, 2019 11:32 AM
Dutchy3051
Milwaukee Eight (M8)
Jan 10, 2019 09:10 PM
Wisenheimer16
2014-2024 Touring Models
Sep 28, 2018 05:58 PM
MisterSlim110
Screamin Eagle CVO Models
Jun 4, 2018 05:39 AM
Wilks132
Jul 2, 2012 07:26 PM
