Code Issue
Old Aug 18, 2014 | 05:43 PM
dg6450's Avatar
dg6450
Stage II
Default Code Issue
Have a 2010 Ultra Classic. Went to a solid idle today and the check the check engine light came. Pulled over and checked the codes and this is what I got: "d1A9". When I try to clear I get: "no rSP". Was able to clear them and let it cool off; then winged it home. When I turned the last corner to head to the house, I opened the throttle up quite a bit, and it sputtered and went back to the solid idle and check engine. Same codes showed up. Called the almighty Harley Shop just to get a better handle on what the codes mean, and was told "can't really tell what the codes mean unless I am looking at he bike". I get it; they want to fix it and make a dollar. Can anyone offer any insight on these codes, and if it requires a Genuine H/D Mechanic to fix to correct it?
Old Aug 18, 2014 | 05:48 PM
SBates08's Avatar
SBates08
d1A9 is not a code. What your actually seeing is "diag" for diagnosis. You need to delve further to retrieve the codes.
Sounds to me like it went into Limp Mode. Check the Throttle Control Actuator. It's at 9oclock on your throttle body. Unplug it and plug it back up several times and add some dielectric grease to it as well.
2010 Limited with some stuff
Old Aug 18, 2014 | 07:01 PM
SBates08's Avatar
SBates08
You retrieved any codes yet?
Old Aug 18, 2014 | 07:13 PM
SBates08's Avatar
SBates08
There are step by step instructions in this thread to show you how to pull codes if your unsure.
https://www.hdforums.com/forum/showt...9328&styleid=9
Old Aug 18, 2014 | 07:50 PM
dg6450's Avatar
dg6450
Stage II
I will check the Throttle Control Actuator tomorrow, and grease it as you said. Will see if that works and then get back to you. Thanks for your help. Dg
JonGolden
Jun 1, 2016 09:02 PM
limited 0110
General Topics/Tech Tips
Aug 3, 2011 03:06 PM
jschneider
May 25, 2011 11:34 AM
monza66mo
Jun 27, 2010 07:09 PM
lylt
Jan 21, 2010 04:41 AM
