changing belts
Old Aug 19, 2014 | 11:43 PM
el loco rico's Avatar
el loco rico
Default changing belts
I am wanting to change the rear belt on a 94 FLh .Does anyone know if it's necessary to remove primary or can you just pull the swing arm loose and snake belt back through houseing
Old Aug 19, 2014 | 11:51 PM
mkguitar's Avatar
mkguitar
primary and swing arm off ( and clutch assembly too)
this is the time to check the swingarm bushings, tranny seal etc.
consider a swap to chain drive....a busted or worn chain can be changed in less time that it took to type this ( 1 finger, hunt and peck).
allows wider tire like an MU85
make sure you get a manual before you take this on
Mike
Old Aug 20, 2014 | 12:52 AM
bagman1's Avatar
bagman1
Ditto! Mike, do you know what the chain slack should be adjusted to for a chain drive? Im working on bike that has a chain and im not sure if its the same as the old dirt bikes we use to ride.
Old Aug 20, 2014 | 06:44 AM
grbrown's Avatar
grbrown
Chains are just SO last century! I haven't owned a bike with an exposed chain for over thirty years and don't plan doing so ever again.
However the entire primary and secondary does indeed have to come off to replace the belt. IMHO that is the sort of job it is worth taking to an indy - with the right tools and expertise he can do it a darned sight quicker than a novice - unless you want the experience of doing it yourself! You will need a few special tools.
flsoftail
Jun 2, 2014 09:37 PM
twism_23
Jan 11, 2014 11:18 AM
OneBlackFly
Jun 24, 2012 09:12 AM
schoney
Mar 8, 2007 05:04 PM
Brian
Nov 21, 2006 06:02 PM
