belt check
Old Aug 25, 2014 | 07:26 AM
glider1993's Avatar
glider1993
Default belt check
Ok I have the service manual for my 13 sg. It has the belt tension in the front as 5/16 to 1/4 and another section 7/16 to 1/4. Which is right? Do I check belt tension with the back wheel off the ground? what is the proper way? book is useless sometimes. Thanks
Old Aug 25, 2014 | 08:13 AM
grbrown's Avatar
grbrown
The thing those dimensions have in common is 1/4". Personally I always set mine (earlier model) at the generous end, so around 5/16" fits both options. It will be interesting to see what an actual owner does!
Old Aug 25, 2014 | 08:34 AM
hardheaded's Avatar
hardheaded
7/16 on mine
Old Aug 25, 2014 | 10:05 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Wow, I'm impressed you guys can get this belt tension adjusted to 1/16 of an inch. Better than I can do.
Old Aug 25, 2014 | 10:22 AM
ndnguyd's Avatar
ndnguyd
Just had to add a couple more holes in my belt, tension was to loose, 6 months ago I was on the other end of the tension gauge.
Old Aug 25, 2014 | 01:39 PM
glider1993's Avatar
glider1993
Do I check it on jiffy stand or with rear wheel off the ground? What's the proper way.
Old Aug 25, 2014 | 01:41 PM
glider1993's Avatar
glider1993
By the belt tension gauge at about halfway I'm getting about 1/2" to 10lbs. That's on the jiffy stand. It would be different with the rear wheel off the ground, right....What size is the axle nut to get it loose?
Old Aug 25, 2014 | 02:02 PM
mkguitar's Avatar
mkguitar
The procedure and tension spec may vary by year and model...
for instance on my Evos the spec is about 9/16 @ 10 pounds with the riders weight on the bike on jiffy stand ( so you lay over the seat and poke with your hand at the belt).
Your year and model will have another procedure and spec that works best for your bike
I just feel mine from time to time
mike
Old Aug 25, 2014 | 02:07 PM
grbrown's Avatar
grbrown
I've owned belt drive Harleys for over 20 years and always done them parked on the jiffy. I've also always used the factory gauge.
Old Aug 25, 2014 | 02:08 PM
hardheaded's Avatar
hardheaded
i bought the jim's tool for adjusting the belt and it lets you dial it right in.
