Breather /Crank case venting
Old Sep 23, 2014 | 08:59 AM
  #51
EasTexUltra12's Avatar
EasTexUltra12
Originally Posted by fwb35
Here is my breather kit, about $15 total
That looks nice. Kind of complements the air cleaner. One of the few I've seen that doesn't have to be "discrete". What type of filter is that and where did you get it?
David
Old Dec 24, 2014 | 09:29 PM
  #52
gbear's Avatar
gbear
Looking at doing this mod. What are the opinions of coming out of the stock air cleaner through the back of the stock plate. Then run the line up and along the back bone down the frame to the rear of the bike and venting to the ground. If it is vaporized oil this should work. Any thoughts? I am trying not to run it down the face of the pushrods or jugs. As always thanks for the input.
Old Dec 27, 2014 | 04:51 PM
  #53
Sam D.'s Avatar
Sam D.
Bought my 1/8" NPT Brass fittings & Brass T fitting , 5/16' Fuel Line & High Temp Red RTV Silicon today, and will pick up my Crankcase filter from KC Int'l when they open Monday... Will drill & tap my SE backing plate Monday.
My Bike did not drip oil from the Stage 1 filter till I changed out the SE filter element with a K&N 0800 Filter element about 2 mths ago,,, but the inside of the SE Filter was soaked with oil just did not run out. Now everytime I ride it it drips on the cam chest cover...
Old Dec 27, 2014 | 11:27 PM
  #54
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by Delta
You know, if you put together a kit that included the fittings, and directions on how to tap them, I would definitely purchase one, along with the Discreet System and external breather. I have the same 110 air cleaner as the OP.
Just a thought.....
We now have these available...both with black hose and with braided Stainless Steel hose. See them HERE
Originally Posted by bigwavdav
Yeah, which part of the bike is the hose positioned so that it drains to the ground. I tried it just after the shock mount behind my bag and got fluid on my rear fender and muffler
Use a filter on the end of the hose. The filters we use will absorb the carry-over oil (blow-by) on a typical HD for 5,000 or more miles of riding.
If you wash your ride at least every 5,000 miles, then just spray a little soap on the filter (you don't need to remove it), let it set, then spray it off after a few minutes and the absorbed oil is cleaned out of the filter and it is ready to absorb more.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Mborras1
Mar 19, 2019 03:58 AM
CJeep
2014-2024 Touring Models
23
Feb 15, 2019 01:30 PM
snowboarder
Jan 23, 2019 06:54 AM
HogHal
Jun 10, 2017 11:06 AM
RoadKingHellas
Jul 8, 2010 02:49 AM
