No Speedometer after PCIII Install "FIXED!"
Old Apr 8, 2007 | 08:49 PM
Max96's Avatar
Max96
Default No Speedometer after PCIII Install "FIXED!"
Just installed a true dual kit along with a PCIII. NO SPEEDOMETER! F-n thing wont work and is kicking out a "P0505 Loss of idle speed control" code. The bike stalls when you come to a stop but starts back up and idles no problem. I disconnected the PCIII and the speedo still does not work.
Old Apr 8, 2007 | 09:09 PM
Law Dawg's Avatar
Law Dawg
From: Rep of Maryland (currently serving in Afghanistan)
Default RE: No Speedometer after PCIII Install
Sounds like you may have shorted something out, when you installed the PCIII. Maybe along short but check all your fuses.
Old Apr 8, 2007 | 09:12 PM
Taterdog's Avatar
Taterdog
Wow, didn't have that happen to me when I recently installed true duals and the PCIII on my bike, but mine is a 2000 and yours a 2006. I'm not familiar with the '06's -- do they have the same analog speedometer I've got, or is yours digital? Did you remove the negative terminal on your battery before you started so's as not to blow a fuse or something?
Don't know where you bought your PCIII, but you might want to conact them or Dynojet and ask for help.
Surely someone with lots of experience can help here.
Old Apr 8, 2007 | 09:15 PM
mrsr71's Avatar
mrsr71
ORIGINAL: Max96
Did you disconnect the "master" fuse before you started the install?
Dan
Old Apr 8, 2007 | 10:32 PM
Max96's Avatar
Max96
Thanks for the info. No, I did not have the battery disconnected or the master fuse removed. From what I am reading, it could be a fuse or the speed sensor. Going to check the fuses tomorrow and make sure the speed sensor is clean also.
Old Apr 9, 2007 | 08:00 AM
jbhawley's Avatar
jbhawley
uggggghhhhhh.
didnt disconnect the negative battery cable...
seems like that is the number 1 instruction on every thing to to with a bike.
oh yea...we real men dont read no stoopid instructions!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 9, 2007 | 11:27 AM
son7771's Avatar
son7771
It says in the instructions that you need to disconnect the battery. You also may need to set the idle after installing pipes and other things. Also after setting the idle you need to unhook the battery for a while to let ecm reset. I would just try unhooking battery fora half hour and try agian. Hope it helps.
Old Apr 9, 2007 | 02:23 PM
Max96's Avatar
Max96
It does not say in the instructions to disconnect battery. Take a look... http://www.powercommander.com/downlo...eng807-511.pdf
From all of your advice, I went and checked the fuses, all good. Pulled the speed sensor... BAM! It was not connected on other end. Couldnt see it in my poorly lit garage last night but after pulling sensor out it was clear as day what the problem was. Most likely used the "id10t" grease by mistake instead of the dielectric stuff that it says to use in the instructions. Zipped it back up, took for a ride, perfect...
Thank you to all for your help. This forum rules!!
Old Apr 9, 2007 | 02:49 PM
THABULL's Avatar
THABULL
I just went and reread the instructions that came with my PC111 and all it said was the ignition must be in the OFF position, it says nothing about disconnecting the battery.
Old Jul 15, 2013 | 11:56 AM
Cptlou's Avatar
Cptlou
Stage II
Mine is doing the exact same thing what did you find for the solution???
