Battery issue?
Old Aug 31, 2014 | 08:16 PM
dochawken's Avatar
dochawken
Default Battery issue?
Thru my leg over the 12' RG this morning...pressed the start....click...click...clck. Hmmmmm I get my volt meter...it shows 13.01 volts static...press the start... 9.10v...so I charge it over 4 hours , 2 amp charger until full charge...try it again. 13.47v static.... 10v pressing the start button. Click...click...click...never had a Harley battery go out in under 3 years. But it appears it has....unless starter has failed? Any insight?
Old Aug 31, 2014 | 08:18 PM
dawg's Avatar
dawg
Notice it's a 2012, did you have the VR replaced under the recall previously? Did you check the cables for tightness yet?
Old Aug 31, 2014 | 08:33 PM
dochawken's Avatar
dochawken
Cables...tight! Did not know about the VR recall for the 12' dawg...but will investigate. Thanks...
Old Aug 31, 2014 | 08:58 PM
mkguitar's Avatar
mkguitar
I thnk your battery is pooched.
charge overnight, load test it at autozone.
many of us use the deka/ big krank.
about $100, mine came from batterymart thru amazon
while a bad VR can kill a battery...a duff battery can also kill a VR and stator.
as can a bad cable
a good charged battery is crucial to all charging system checks
mike
Old Aug 31, 2014 | 09:02 PM
Pioneer74's Avatar
Pioneer74
You can enter your VIN on the HD website and it will tell you if your bike is part of the recall. I had mine changed at my 1000 mile service.
Old Aug 31, 2014 | 09:27 PM
dochawken's Avatar
dochawken
as can a bad cable
mike
I have the deka in 3 of my other bikes...the one in my Heritage is 8 yo....no issues...keep on tender as all others.
Old Aug 31, 2014 | 10:00 PM
mkguitar's Avatar
mkguitar
oh..are you touring right now?
I saw your sonoita post-
if so a bad vr may have overcharged your battery and be killing it- a conventional type may need distilled water added.
if you make it to PHX and have trouble, pm me.
I got some tools- if you need to have a battery shipped you can ship here...or do a swap with me.
my deka battery is only a few months old.
mike
Old Sep 1, 2014 | 07:50 AM
tsigwing's Avatar
tsigwing
Just replaced mine with a Yausa 500 cca battery. Starts up much quicker, even a quick restart when hot. Peace of mind was worth it.
Old Sep 1, 2014 | 08:09 AM
dochawken's Avatar
dochawken
mike
Thanks Mike...I jumped on my Softail and took off, left the RG on the charger all day.
Old Sep 1, 2014 | 05:36 PM
dochawken's Avatar
dochawken
Put a AGM battery in it...load test showed battery was gone.....wow those little dudes are expensive! Amazing the cost increase in 3 years...but when you live in a remote location and have plans for the coming week...you have to suck it up!! Lol
