Passing Lamp Recommendations
My current set up is Truck light P7, Dynamic Rings, and HD foglamps w/ led conversion. (The Rings & foglamps do nothing). Considering passing lamps but equally important is I want it all to match. Hense the LED conversion on the fog lamps.
How are the Truck light passing lamps? Can I keep my Dynamic rings w/ bullet turn signals. If I get the HD set up I know I can keep the bullets but what bulb will match my TLP7 headlight.
09 Street Glide.
What type of bulb do the HD ones use? Part number 69818-06.
Wire them in with a Bosch relay, and I'd suggest rewiring the spotlight switch to work independent of the headlights...a simple 'on' or 'off' will work fine, because you don't want those things coming on accidentally! They WILL turn night into day.
Being in SoCal, it's not often that there aren't other drivers on the roads, even in the early morning hours, and you WILL blind oncoming traffic with these things...but if you're looking for something that will really, and I do mean really, light up the road, these are them! I've been using these bulbs for over 35 years on my motorcycles and other equipment. They are VERY effective for lane splitting...and can be actually annoying, which works in our favor, I reckon.
I was going down a deserted road last evening with a friend, came up alongside, and fire those puppies up...I think a bush along the road burst into flame!
Anyway, if you're looking for bright, nothing better...you'll have to put a couple of ring connectors on the wires. No, I have no wiring diagram, anybody whose competent with vehicle wiring will be able to easily figure out how to wire these in, and there are a number of interweb sources for wiring the Bosch relay.
ADDITIONAL INFORMATION: There are internet sources, Amazon for one, that lists these bulbs for under $8.00 apiece...can't beat that.
http://www.harley-davidson.com/store...-11-6981806--1
http://www.harley-davidson.com/store...CatEntryType=2
What about matching them up to look the same as my TLP7?
http://www.harley-davidson.com/store...uxiliary-lamps
That's a lot of cake!
