Switch problem after ape install
Old Sep 1, 2014 | 04:00 PM
kenbibby's Avatar
kenbibby
Stage III
Default Switch problem after ape install
Just did ape install on FLHTK. Did test of all switches. Now after zip ties installed, right turn signal turns on fuel pump and run switch turns on right turn signal. Did I pull a wire loose from the connector. The connector did not seem to lock together and snap on install.
Old Sep 1, 2014 | 04:09 PM
shakrr's Avatar
shakrr
double check all wires are in right place in the connector
Old Sep 1, 2014 | 04:17 PM
Ragtop's Avatar
Ragtop
^^^this^^^
Old Sep 1, 2014 | 04:42 PM
Puggy's Avatar
Puggy
You got two of the wires swapped. Figure out which ones go to the run switch and the right turn signal, swap their positions inside the connector and you should be good to go.
Old Sep 1, 2014 | 04:51 PM
kenbibby's Avatar
kenbibby
Stage III
Found problem crossed w/blk & w/bn pins in connector. Must have only thought I checked function before tying up wires. I sure sucks repining connectors in fairing. I will triple check next time.
Old Sep 1, 2014 | 04:52 PM
kenbibby's Avatar
kenbibby
Stage III
Thanks guys!
Hey Man
EVO
Sep 21, 2017 03:21 PM
Chris1957
Electrical/Lighting/Alarm
Sep 3, 2016 03:59 PM
HDeuce
Jul 9, 2015 03:21 PM
NJ75
Jun 5, 2011 12:19 PM
nutsandbolts5212
Feb 21, 2010 12:10 PM
