How does this happen?
Old Sep 8, 2014 | 07:36 AM
jamesroadking's Avatar
jamesroadking
I've changed a lot of tires over the years and I have never had to remove the pulleys or the rotors to do just tires.
Old Sep 8, 2014 | 07:42 AM
STLFLSTF_Mike's Avatar
STLFLSTF_Mike
There is a ways two determine if a bolt sheared off due to over torquing or due to side load issues. If the bolts failed due to shear only you will be able to see a planer grain failure, if they failed due to over torquing you will be able to see a circular pattern in the ductile material. The problem is getting a high power view of the failure area of the bolt. BTW I have never remove mine to change the rear tire (Fatboy).......I have not had to change the rear on my SG yet.
Old Sep 8, 2014 | 07:52 AM
Imold's Avatar
Imold
I'm getting suspect of Harley parts, so many from China, and not all bolts are grade 8, either. I get grade 8 bolts elsewhere, and hope when they claim American made, they aren't lying. But actually, I'd go with the loose or over torqued theory, too, that's common; a lot of mechanics have "calibrated" arms and don't use torque wrenches. I'm not one of them.
Removing pulley - that can depend on the tire changer, too. You can see in the pic that mine needs either the pulley or the disk removed to use the bar. Since this one was off a used bike, I removed the pulley so I could be sure it was put on with red loctite and the correct torque, but removing the disk is easier; no need to remove both on mine. Not all changers are the same, though. I've used spoons before, and removed both disk and pulley to avoid damage, though if you're really careful you could do it without removing them.
Old Sep 8, 2014 | 08:27 AM
bigheadted's Avatar
bigheadted
I have reused the factory pulley and brake disk bolts and as of yet not a failure. I do use loctite and a torque wrench. Removal of these items for tire removal depends on the installer and machine.
I have a pulley with 900 miles from a 2007 or 2008 Ultra for sale if needed.
Old Sep 8, 2014 | 09:45 AM
Woodchuck's Avatar
Woodchuck
Was your '07 retrofitted with IDS? Some of the first generation IDS installations in '07 experienced the bolt shearing problem. The failures occurred fairly soon after installing though, not years after like yours.
Old Sep 8, 2014 | 10:11 AM
Hogpro's Avatar
Hogpro
Former Sponsor
No red loctite and not torqued properly with new bolts. Red loc tite new bolts torque to 65-75 ft lbs. I see this all the time. Pulley's do not usually need to come off for a tire install but it depends on who is doing it and what tire machine they are using.
Old Sep 8, 2014 | 11:20 AM
51Moe's Avatar
51Moe
Same happened to me, but not all. Maybe 2 or 3...I think my problem was insuffecient torque. Once replaced with correct tq, (knock on wood) I havent had a probelm.
Old Sep 8, 2014 | 11:59 AM
EasternSP's Avatar
EasternSP
Originally Posted by Sparky277
Rear drive pulley on my 07 road glide bolt heads sheared off. All of them. Unbelievable. Had my rear tire replaced in July. Could it be the bolts were not properly torqued? Now that I think about it, does that pulley need to be removed to change the rear tire?
Any damage to the swing arm?
Old Sep 9, 2014 | 07:57 PM
Sparky277's Avatar
Sparky277
Stage III
Thanks for the comments guys. I'm still floored that this happened. I'm going to see about removing the rear wheel this weekend. I haven't been able to get a good view on the inside of the swing arm. Hopefully I am not going to have to replace the swing arm or the rear wheel.
Rubline
May 7, 2018 05:33 PM
Tucker99
Apr 4, 2014 08:35 PM
Sledhead83
Jul 8, 2013 12:53 PM
SpiderPig
Nov 6, 2012 04:57 PM
seniorsuperglideE8
Oct 30, 2007 07:41 PM
