Rear wheel alignment
Old Sep 10, 2014 | 02:32 PM
roadking2014's Avatar
roadking2014
thats a good note in there about the rear wheel offset. caused me to re think my adult beverage consumption the first time using a string from the front wheel.
Old Sep 10, 2014 | 11:03 PM
OwnerOfHarriet's Avatar
OwnerOfHarriet
Originally Posted by grbrown
It works fine with a stock set-up, agreed, but as soon as we go away from stock the wheel may indeed need to be reinvented! With my set-up, using a wider rim and tyre, checking the alignment from first principles, the cams reveal that the wheel is offset slightly to the left.
btsom's description is excellent, however there is another aspect of wheel alignment which the manuals don't often cover, namely how the rear wheel relates to the front one. In an ideal world the rear should follow the front in perfect alignment. I'm currently working on a solution to adjust mine so they do that, as well as they can.
check out pro glide bushing -- he has a video on aligning front to rear wheels -- I know it works on the pre 09 not sure about 09 and newer
LX2
2014-2024 Touring Models
Mar 4, 2016 12:51 PM
blackflame
Sep 11, 2013 02:49 PM
ga guy
Jun 15, 2010 12:16 PM
harley1425
Sep 28, 2009 03:35 PM
DCS
Jul 26, 2007 09:56 PM
