V & H power duel question
Old Sep 15, 2014 | 06:53 PM
ron1z's Avatar
ron1z
Default V & H power duel question
I just ordered a V&H power dual for my 14SG. Are the 02 censors going to line up with the new pipes or do they have to be extended?
Old Sep 15, 2014 | 07:03 PM
RollaMo's Avatar
RollaMo
If they are the correct model for your year bike, they should work just fine.
I don't have a '14, but have the Power Duals on my '11.
Unscrewed the o2 sensors from the factory pipes and screwed them into the Power Duals.
No extensions.
Old Sep 15, 2014 | 07:58 PM
xcrider's Avatar
xcrider
No extensions.
I have them on my 2012, O2 went right where they should be. Just watch the wire routing so that they don't get close to the pipes.
Old Sep 15, 2014 | 08:06 PM
xhere's Avatar
xhere
I have them on my 14 and they work fine. The rear O2 sensor will go straight down and around trans cover.
Old Sep 15, 2014 | 09:44 PM
Aversocki's Avatar
Aversocki
They fit fine on my 14 SGS. There isn't much slack at all on mine routing back the same way as the stock wires were but they do work.
Old Sep 15, 2014 | 09:53 PM
craigffb's Avatar
craigffb
I re-routed mine a little and they are fine. They provide a new clamp for the wire. They are the same pipes from 10-14, and I would guess 15 as well. Here's the instruction sheet to look over before you get em and install.
http://vanceandhines.com/download/D793IN.pdf
lewain
Apr 22, 2013 06:03 PM
glcash
Sep 10, 2012 09:43 PM
617south
Fuel Moto / Jackpot Mufflers
May 27, 2010 12:39 PM
Mordrapheus
Sep 21, 2008 06:12 PM
07 desert sled
Exhaust System Topics
Sep 20, 2007 09:03 PM
