2013 CVO roadglide W/Tman124
Old Sep 16, 2014 | 10:19 PM
sporacer's Avatar
sporacer
Originally Posted by SafetyMan
Sorry if I sounded like I was bashing, I wasn't.
To be honest, those are stinkin awesome numbers, and I'm a bit jealous, and concerned.
Enjoy!!
I'm really not worried I have a customer's 107 with tman nic cylinders and almost 10000 miles this year.
Old Sep 17, 2014 | 12:12 AM
equandt's Avatar
equandt
Nice numbers. I hope you enjoy buying new rear tires!
Old Sep 17, 2014 | 08:00 AM
hd_rolling's Avatar
hd_rolling
So I'm wondering at what point your SE 5.3 injectors are holding anything back, I thought they were only rated for up to 120 HP?
Old Sep 17, 2014 | 08:48 AM
slammed05fatty's Avatar
slammed05fatty
wow, that thing is a beast.
did you change over to chain drive or still running drive belt?
Old Sep 17, 2014 | 04:10 PM
sporacer's Avatar
sporacer
Still running a belt. I also added the dyno sheet.
Old Sep 21, 2014 | 03:21 PM
sporacer's Avatar
sporacer
I just wanted to update everyone on my 124 build. I was able to get a good 200 mile run in today. No highways but good cruising roads with corners. I was getting 40.1 mpg hand calculated. So far this monster is doing all the right things. Another bonus is its much cooler running than the stock 110 that it replaced.
Old Sep 21, 2014 | 04:24 PM
hog95023's Avatar
hog95023
Unless held at wide open throttle for extended periods I don't think the injectors will be an issue. I am using them in my 124 but I have a little less compression and a few less peak numbers.
OP your build looks very nice. Congratulations. I put 20k miles on mine in about
1.5 years and it is a blast yours appears that it should be even more fun to ride.
Old Oct 1, 2014 | 09:56 PM
fmlawn's Avatar
fmlawn
Default 124 kit
any hard starts..do you have lowers..like to do 124 in my utra roadglide heat ...like to ride long trips...
Old Oct 2, 2014 | 05:34 AM
sporacer's Avatar
sporacer
Yes I do run lowers. This engine has auto compression releases and it starts just like a stock bike. Im really enjoying the crazy power.
Old Oct 2, 2014 | 08:19 PM
fmlawn's Avatar
fmlawn
Default 124 kit
what changes would you have made on 124 kit... starting mind next week
