Ignition switch housing
Ignition switch housing off of my 2012 Limited, part # is 71572-06
Part is basically new, except the little plastic tab that holds in the wiring connector broke off. Doesn't affect the operation of the switch at all.
When I first bought the bike, I switched Handle bars and when I went to remove the wiring harness from this switch, the little plastic tab broke off that holds the connector in. You have to stick a little screwdriver in and bend the tab back to remove the harness and I guess I bent it too far.
For a couple months, I just held the harness into the switch with a Zip Tie. Worked fine, but I eventually just bought a new switch.
Selling this cheap, switch works great, you just have to hold the wire harness in with a Zip Tie.
$30.00 shipped lower 48
Paypal only please
Thanks
Hard to tell from your pic, but Do you think i could use any of the parts from yours to fix it? dont throw it away! if you are planning on throwing it away, i will pay the couple bucks it would cost to ship it to me.
