Have a used set of heat shields. They have normal wear and tear from about 15000 miles of use.
The front and rear pipe shields are scratched where they met up with the collector shield. I didn't have any issue with this but YMMV.
Also noticed a couple small dimples on the collector shield where the clamps are welded from the inside.
You can use these as is or get them powder coated.
Includes full set but does not include the cross under pipe pictured. Just the small shield that is attached to that pipe. 4 pieces total.
