I think that you may be on to something. If I push the trike from side to side it
squeaks very loudly. The sound seems to be coming from the area of panhard rod. That is where I'm going to look next. Can I get at it without pulling the body?
You can try, but the panhard rod sits pretty hi up in front of the lower trunk. I guess if you have long skinny arms that would work.
That panhard rod does have a habit of wearing out the rod ends. But the good news is you can get new ones from a bearing house instead of MOCO.
I wonder if the rod ends that I could get from a bearing supplier would be any better quality than the ones that H-D put on the bike as original equipment.
You may or may not need to replace the joints. They are supposed to pivot but not have any slack or looseness. I caught mine early enough to get by by just greasing them real good.
LOL Whatever you do don't use WD-40 or you'll be pulling the body off again in 6 months. I know screwball was just joking but just a word of caution re lubricants.
There was a service bulletin about this. Bulletin # M-1339 applies to all 2009 -2013 Trikes built before Feb. 02, 1013
They will replace the rotors and pads. It happened on my EARLY 2013. The dealer replaced the rotors with part # 83425-09B and the pads with part # 83911-09B
Not a single squeak since then. No charge. (Really should have been a recall, but the MOCO is hoping that people won't complain). I can scan the service bulletin for you, but I don't know how to get a scanned image to post here. You can send me an email at tsw555@verizon.net if you want a copy. Remember you have to inform the dealer about the squeak and this service bulletin. Good Luck!!
Sorry for the above post; I didn't read good enough. It is apparently NOT a brake squeak.
But.... the info is good for anyone having brake squeal problems.
A lot of time you can find something a little better quality than what HD installs, HD sources a lot of parts from the cheapest supplier, not always the best quality.
