Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri Glides question
Old Sep 11, 2016 | 12:56 PM
Backdraft161's Avatar
Backdraft161
Default Tri Glides question
I recently purchased a 2016 tri-glide and have a question. It is not covered in the owners manual.
Where can i find the connection for adding power to my road zeplin seat? Also the electrical adapter harness that i bought has 3 wites that look to be connected also. Where do these go?
Thanks in advance for any and all help.
Old Sep 11, 2016 | 01:58 PM
so60's Avatar
so60
Backdraft161, if you bought the adapter required per the instructions. you just use the two regular "plug" ends. It plugs in under the left side cover using the accessory connector already there. You have to feed the other end up through the frame area and it just plugs into the connector on the Zeppelin seat. The other three wires are just hot leads that can be used for other things if you need them in the future. It should have come with three sealed splice connectors for use with the three leads. I did not use any of them and just left them attached to the adapter harness. I think I did put a small zip tie around them just to hold them in place against the adapter. Also, the accessory connector on the left side that you need is the "lighter colored" one. The part number for the adapter I used was a 69200722. Here is a picture. The bottom connector is the data connector use to access the engine computer and to use a tuner etc. Also, the picture and info is on page 57 of the 2016 Trike owners manual.
Old Sep 11, 2016 | 03:23 PM
Backdraft161
Thank you so much! You are the bomb!
Old Sep 11, 2016 | 03:30 PM
so60's Avatar
so60
Also, for quick reference it is on page 57 of the 2016 Trike Owners Manual.
Old Sep 11, 2016 | 03:53 PM
Backdraft161
So60 you ever come to the panhandleof Florida i willbuy you a beer. I live in Baker.
Thanks again.
Skid /18\
Feb 21, 2019 10:08 AM
Jethro
2014-2024 Touring Models
Jul 27, 2017 10:41 PM
paullavery
Milwaukee Eight (M8)
Jul 6, 2017 06:37 AM
squirrelrequiem
Apr 23, 2015 10:51 AM
blownrocket
Jan 20, 2010 07:55 AM
