Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
2014 HD Tri Glide Ultra CB Antenna
Old May 26, 2017 | 12:47 PM
trike2014's Avatar
trike2014
Stage III
Default 2014 HD Tri Glide Ultra CB Antenna
What is the best I should see for the SWR reading with the 33" antenna for CB. I was getting 3:1 then I started cutting off 1/8" at a time and got it down to just under 2:1. Has anyone had any luck getting it lower than that. Right now the total length of the CB Antenna is 28".
Old May 26, 2017 | 07:47 PM
sloufoot's Avatar
sloufoot
I don't think you will see anything below that SWR. I can't get mine down that low.
Are you using the metal antenna, or the loaded antenna?
Old May 27, 2017 | 08:32 AM
trike2014's Avatar
trike2014
Stage III
Default Cb swr
I believe it's the fiberglass with a load at the bottom.
Long lonesome highwayman
Nov 2, 2018 07:19 PM
HDJIM1158
Dec 7, 2016 02:50 PM
Keystone
Audio Systems
Apr 3, 2015 06:41 AM
Texas Rider 3
Audio Systems
Mar 22, 2013 08:06 AM
Weatheredge
Jul 19, 2012 11:47 AM
