Here is a update on P&A connector when you have the wiring adapter. Connector 325 is located behind the right side cover and is located just below and behind the reverse solonoid.Thats the one with the reset lever on it. Black connector is a 2 wire with a violet/blue wire and a black wire. Just pop connector off plastic cap it is attached too and plug your three pin adapter connector into it and fans will work with ignition switch.
iThank you all for your assistance. At this point I have installed the Middle dash switch on LH dash and the two ACC buttons and housing for the RH dash.
Now I need to connect the wiring harness to both the Battery and to a power source! I am using the Left Side Panel (black connector with the four wires) that connects power to the switches. BUT, the kit provides a fused wire that has a ring for the positive battery terminal on one end and a "pin" on the other which needs to connect to the female end of a 3 pin Molex 150 plug. That plug (925A/B as the instructions from HD call it, is being used already for my cool flow fan.
My QUESTION is Can I insert this pin into the same connector as the fan is plugged into? Hope this is clear. Both my 925 plugs are alren ady being used.
Thanks for the update re P&A connector. That connector already has a plug with three wires going into it, part of the Update wiring harness the Dlr installed when bike was new. I am now adding another harness for the three RH dash switches. That is why I need to find a place (directions say a 925B, to plug into. I cannot find an additional 925B.
I have Cool Flow Fan, Air compressor, XM, Whim, and now I want to have switches to activate Fog Lights, Love Jugs, and maybe more lighting.
Thanks for your assistance, very much appreciated.
