Can anyone tell me where I can get the connector used on the 12-volt auxiliary power outlet in the tour pack? Male and female . I'm not sure if it's Molex or not.
What year is your trike?
I have an '18 and I added the tour pack power outlet (like I have in my CVO Ultra) and I may be mistaken but I'm pretty sure that the power wire and connector was already in my tour pack.
Have you lifted out the liner and looked to see if your has one also?
I installed a 12-volt power outlet in the trike in 2019. I'm looking for the plugs that were used to make an extension wire.
Without seeing your connector and knowing year model I am guessing you have AMP connectors.
You can google Amp connectors and find a match for yours or you can get in touch with Namz wiring
and they can fix you up with anything you need,
If you find out for sure what connector you have Amazon has all types.
