Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
More Oil, Less Heat
Old Sep 11, 2009 | 05:52 PM
2Sore's Avatar
2Sore
Increasing oil capacity really only gives you a longer oil change interval. It doesn't really do a lot for cooling. Adding another oil cooler would be more beneficial.
Old Sep 11, 2009 | 06:28 PM
0734's Avatar
0734
As for the floorboard cooler heat burning your feet... I don't think so. The same question always arises when the crash-bar cooler comes up. Guys say they will burn their hands or melt-down the fiberglass on the lowers...neither of which are true. I'd be more concerned about the price and like posted above, the plumbing. It mentions "by-pass" valves and you would surely want one on any cooler, unless you use the sandwich adapter that has one in it. Plumbing-up vales under that frame can wind up being very unattractive and messy. Using ONE with the sandwich adapter, you could make a real neat installation. I may have to try one of these when the get off the "price coming soon" thing and put a figure on it. It looks bullet-proof.
Old Sep 11, 2009 | 07:45 PM
motordad's Avatar
motordad
Aren't floorboards one of the first things to scrape in tight corners?
Old Sep 11, 2009 | 08:31 PM
coupe55's Avatar
coupe55
Default Baker Pan
Originally Posted by krw
I wonder if adding something like the Baker oil pan, which gives you another quart of oil, would help cool down the engine?
http://www.bakerdrivetrain.com/flt/index.htm#p1p
The web site says it reduces temp 10 deg on a 80 deg day.
Might if you are running an oil cooler! I don't think it will help with the heat situation we have. Lean AFR plus now catalytic converters. The bottoms seem to be holding up, you get enough oil splash on the piston bottoms and cylinder walls. It definately would help but on the 2010's losing the cat and getting a tune would cool down the head area, especially on that rear one that is taking a beating.
I don't hear as many complaining on the 09's once they go in for a tune and richen up the fuel. Richen up the AFR and you cool it down some. You do this on a 2010 and you may clog up the cat over time and make it hotter.
I went with a 10 row jagg using the same principle, more oil and more fins, 40% more cooling over the 6 row Harley hangs on the Tri's. Help's in the wind but in slow traffic and at lights the cooler does not do it's job. Went with the Lenale Fan for lights and traffic jams, just another bandaid until I can get the two main fixes put on it for the heat. Lose the cat and tune.
You will have people in the know come on here and say the complete fix is change those overlapping cams and tune. They are set up more for EPA than engine efficiency. They are right, but that is high dollar, I'm talking the bare bones minimum to get some extended head life. The EIMTS heat management system will kick out that rear and suck air long enough to cool the sucker down through the warranty period.
I am just wondering about extended head life, the CVO's are claiming head damage early, gasket and leaks. 20 to 35 thousand miles for some. They have had the cat for several years and IMO that cat is holding in heat causing a lot of the rear cylinder head failures!
Old Sep 11, 2009 | 08:38 PM
krw's Avatar
krw
But not on a 3 wheeler
Old Sep 11, 2009 | 08:51 PM
Mr. Wizard's Avatar
Mr. Wizard
Too funny but very true.
coupe.. that's a great attitude you have.
Old Sep 11, 2009 | 08:58 PM
coupe55's Avatar
coupe55
Default Dropped My Trike
And we should never have to worry about dropping one but if there is anyway it can be done I will be the first to do it!
Old Sep 11, 2009 | 10:18 PM
quigley's Avatar
quigley
I use a oil cooler and a fan kit. I can sit in traffic all day and the temp never goes above 215F
Quigley
Old Sep 12, 2009 | 05:13 AM
0734's Avatar
0734
Those things look pretty beefy and durable. I had toyed with a way to get a remote filter housing down under there and use a canister rather than a filter, like one of those units that have the insert as opposed to the spin-on. The thing is out in the wind and is not right there in front of the motor blocking precious cooling air. I suspect I will have to try one. I sure think with the wafer adapter and some built-up stainless steel lines...it would look real cool.
FLTR2008TRIKE
16
Oct 6, 2018 08:48 PM
Mississippi Birdman
Feb 5, 2011 03:23 PM
fabrik8r
Sep 16, 2010 01:29 PM
rocksandgiz
Mar 26, 2008 07:54 PM
Big Papa75
Oil Archive (no new posts)
Mar 2, 2008 09:20 PM
