Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
More Oil, Less Heat
Old Sep 11, 2009 | 07:09 AM
krw's Avatar
krw
Default More Oil, Less Heat
I wonder if adding something like the Baker oil pan, which gives you another quart of oil, would help cool down the engine?
http://www.bakerdrivetrain.com/flt/index.htm#p1p
The web site says it reduces temp 10 deg on a 80 deg day.
Old Sep 11, 2009 | 10:40 AM
TheJimer's Avatar
TheJimer
I didn’t see the “TG” listed on their applications list, do you know if they build a pan for the TG? Also, are they saying that their “FL-Fill Spout is the new dipstick for the added capacity?
Would be great....if it really works!
Old Sep 11, 2009 | 03:00 PM
carlo's Avatar
carlo
Jim it looks like its the same but deeper. The TG has a plate under the pan thats kinda wide' looks like the Engine and Trans would have to be pulled out to install the oil-trans pan don't know if it would clear the plate thats part of the rear frame. It was a thought till I looked under the TG.
Old Sep 11, 2009 | 03:44 PM
0734's Avatar
0734
It is a bit of a pain to replace the oil pan, not impossible by any means, but you usually have to remove the swing arm connection (rear motor mounts) at the frame and jack the rear of the motor up a bit. There is surely a step-by-step out there complete with pictures somewhere. I'd go study that before I decided to do it. Another quart of oil surely helps, but you can do the same thing with a well installed remote oil filter, or even a crash-bar cooler. You can get close to another quart in there with the crash-bar cooler. Some folks shy away from a crash-bar cooler, but that concept has been around many, many years and I have ran one on the last three Harley's I have owned. It's out of sight, out of mind, in the wind, very durable, holds some additional oil and you can reach down there and warm yours hands on those cooler days. I have read some comments on the over sized pan and one consideration is that it is not "in the wind". It just takes a bit longer to get 5-6 quarts as hot as it does 3-4 quarts, but if you cannot cool it, it will eventually get just as hot. On the other side of the coin, on the cold days it takes a bit longer to get that same 5-6 quarts up to operating temperature.
There is always a pro and con to anything I suppose.
Old Sep 11, 2009 | 04:41 PM
TheJimer's Avatar
TheJimer
Thanks Carlo and VT, it sure seems like a lot of work to change out an oil pan!
Vt, the point that you make about the extra quart of oil “eventually reaching the same temp.” is certainly a valid argument! So after buying the Baker Pan, going through all the work to install it…all I would achieve is 15 min. or so of reduced oil temps.
Doesn’t seem worth it! Thanks again guys…I love this site!!!!!!!!!!
Old Sep 11, 2009 | 05:07 PM
0734's Avatar
0734
I don't knock Baker and I have one of their 6-speeds in my trike.
Obviously, more oil would mean cooler oil, but for how long. I just think you could get more oil capacity without spending all those bucks for the pan and the change. I have heard one of the aftermarket firms is working on "floorboard" oil coolers. I can't wait to see what they have came up with.
Old Sep 11, 2009 | 05:22 PM
carlo's Avatar
carlo
Remember Org split gas tanks one side gas the other was a oil tank. Can allways find a place to hold more oil. Frame tubes. You got that right Baker builds some of the best stuff out there.
Old Sep 11, 2009 | 05:29 PM
krw's Avatar
krw
How about Floorboard Oil coolers? Mt. Wizard sent me a link. I found this web site:
http://www.dmcustomcycle.com/floorboard-oil-coolers.php
Old Sep 11, 2009 | 05:47 PM
Mr. Wizard's Avatar
Mr. Wizard
Here is the instruction sheet for the Baker pan. Don't panic, it was written on 08.
Old Sep 11, 2009 | 05:50 PM
carlo's Avatar
carlo
Would the floor boards make your feet hot? Plus the more oil lines greater chance for leaks. Back in my hot rod days I was told that Chrome held Heat. Black dissapates Engine heat better. I use a HD black oil filter on my TG. not that its going do any thing substantial. If I were to go with Floorboard oil coolers id go with the black. I was wondering if a Head and cylinder set up could be made with cooling passages for the oil to flow through. There by increasing oil capacity and cooling at the same time. But still having inessence a air cooled engine.
