Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
2011 tri glide changes
Old Dec 18, 2010 | 11:52 AM
b0bberd0wn's Avatar
b0bberd0wn
Stage II
Default 2011 tri glide changes
Hello all, I am considering buying a new tri glide. My local dealer has a new 2010 in stock. I'm wondering if there were any changes or improvements in the 2011. I believe reverse is standard on the 2011, any other changes? Thanks, Bob
Old Dec 18, 2010 | 11:55 AM
carlo's Avatar
carlo
Welcome Go to the TriGlide section. Tons of info on the 09-10-11 TG's
Old Dec 18, 2010 | 11:58 AM
Mr. Wizard's Avatar
Mr. Wizard
Thread moved....
Welcome to the HDF
Old Dec 18, 2010 | 12:55 PM
tbob's Avatar
tbob
The 2011 will give you better pull with 30tooth front pully and diffrent rear door lock.
Old Dec 18, 2010 | 01:06 PM
Mr. Wizard's Avatar
Mr. Wizard
Maybe this will help.
Here are the 2010 and 2010 Model Year Technical Changes. You will find all the touring/trike/electrical/body/motor updates from one year to the next.
http://www.box.net/shared/fyh8flnhy4 (2010)
http://www.box.net/shared/u9eoh1levm (2011)
Old Dec 18, 2010 | 01:16 PM
oldmsocko's Avatar
oldmsocko
To answer your question. If I were buying a new TG I would certainly purchase the 2011. There were a number of good changes for 2011.
Old Dec 18, 2010 | 02:02 PM
b0bberd0wn's Avatar
b0bberd0wn
Stage II
Thanks for the links Mr. Wizard, looks like the 2011 is the way to go! Thanks again, Bob
Old Dec 18, 2010 | 03:36 PM
msocko3's Avatar
msocko3
Get the 11, the 10 is a kind of the odd duck. The 11 has better gearing and some nice changes with the trunk lock and the best of all it is about $695 cheaper than both the 09 & 10 with reverse being an option on those two model years.
Old Dec 18, 2010 | 07:45 PM
coupe55's Avatar
coupe55
Default Feedback Engineering
It took HD 3 years to get the gearing right. The EPA cost us a lot of money and time on the 09 and 10, the gear can't be forgiven. A lot of the 09 and 10 owners are changing the gearing at considerable expense and effort, this should not have been necessary.
I would buy the 11, it is closer to what the Tri should be with the 30T primary pulley. If they had that on an 09 that come without the catalytic converter HD would have been close to an acceptable stock Trike.
I would definately go with the 11 over a 10. Hindsite is always 20/20 but if I could do a do over, I would have bought the 09 and slapped the 30T pulley on it. For my needs it would be close in stock form and I could have saved a few bucks.
Old Dec 19, 2010 | 06:20 AM
oldmsocko's Avatar
oldmsocko
Coupe: you hit the nail right on the head. Had the MOCO put the 30T primary sprocket the 09 basically would have been right on. After were done this winter I beleive we will be where we will be satisfied. Next winter all we will need to do is sit back and wait for spring unless M3 gets some more ideas for us to try.
